Razor Dune Runner 350 Go Cart Logo
Posted on Jun 13, 2009
Yh250a how do i fit new hand brake cable to yh250a and is there anyway i can tune or custom this engine ?
How do i replace my hand brake cable on my ford falcon XH ute
wait a bit ....is it rear disc or rear drums on that ute
will assume its under dash hand brake pull lever tyoe
the disc setup may have single cables for each rear
rear disk brake cable is approx $ 150
if your XH it is close to the XE and XF set up drums
a complete one line loop cable outer and inner
with plastic grommets along the back chassis rail ( they break )
so the one inner cable works both rear handbrake shoes
hand brake cable is a shorty
undo the adjustment thread
just below the hand brake cable point up somewhere above the gearbox
(drums )
after new cable fitted
drums are adjusted with the old school way with the handbrake adjuster tool
handbrake cable adjusted
then the handbrake handle when pulled out to hold needs14 plus clicks
comes out a long way for some weird reason
on drums
if cable adjustment is done wrong onrear drums the handbrake cable will come loose in the drum as you drive along
What is wrong with the hand brake on my vauxhall vectra C 1.9 fitted new pads and handbrake cable still comes up too high
Hello David, there will be an adjuster but (depending on the age of the vehicle) it might be self adjusting or manual.
Contact customer service : Ask Question Get an Answer ASAP
1.9vauxhall vectra C fitted new pads and hand brake cable now handbrake has too much travel same as before items were fitted
it looks like a common flaw in design
it can fail an mot if handbrake wont hold
with both wheel of the ground and hand brake fully applied do the wheels spin
handbrake cable system on a
1.9vauxhall vectra C says self adjusting
but this picture implys there is an adjustment point
source
Thread Handbrake adjust
you tube vectra handbrake system in action
Opel vectra handbreak
2answers
How do i adjust hand break new shoes fitted on a smart for two hand break lever is all the way uo ?
Adjusting the Hand Brake is quite easy
At the bottom of the Hand Brake Lever , you will see the cable with like nuts (teeth) on the cable locked by the lock on the lever it self, you will need to open the lock , take the cable off the lock , drop the handle down and put the cable back on the lever and lock it.
That is how the hand brake is adjusted on the Smart car 2002 model
I cannot assemble the front brakes properly :(
It probably is too short, those cables can be bought at any length you need it's entirely custom what length you choose.
1helpful
Ive got a ford fiester 1996 n reg and my hand break is not stoping me if im parked on a hill, do i need to ghange the break flud ?
no. you need to tighten the hand brake cable, or if the is tightened to the max already then you need to replace it with a new one.
brake fluid low will be indicated with alight when the car is switched on (the same light that is one when the handbrake is applied will stay on when the hand brake is released.
Anyways, the hand brake is cable operated. This is normal as with time the steel cable stretches since it is put under enormous stresses when engaged.
2helpful
How to change back brakes? I can't get the brake cylinder to go in.
Do you mean back brake pads or the back brake callipers?
To change pads you need to use a rear brake pads changing tool to screw in the calliper piston or if you are experienced enough you could screw in the calliper with a two mm thick piece of metal sheeting that fits into the grove of the piston.
If you need to replace the whole calliper remove the hand brake cable first and clamp the flexible brake hose remove brake hose, remove the callier with cylinder and then remove the calliper holder. fit new holder pads and locks and the calliper with the piston and the brake hose and the hand brake cable. Bleed the brakes. Mike
19helpful
My parking brake cable snapped when I released it . Is it easy to replace or do I need to take it to the dealer ?
I have a 2002 tahoe and the e-brake cable snapped as well. I am NOT good at fixing cars and I did it so I am sure you can too. First thing you will need to do is release the brake. Just look underneath (way to the left against the e-brake pedal and you will likely see the lever that releases the pedal) carefully press up on this lever and release the brake. Next, make sure the old metal cable is completely removed. There is a small hole on the lever you just pushed that the end of the cable goes in as well as a hole on the hand release. Cut the cable off if necessary to remove.
Now, purchase the new assembly (comes with the hand release and new cable and about $40 at a Chevy Dealer - probably a lot less at one of the online retailers like US auto parts). Unscrew the old hand lever and remove. Also remove the cable housing underneath (needle nose pliers to pinch the fitting and remove. Next, take the new assembly and run the housing and the end of the cable through the fitting next to the pedal as it was before. Now you need to carefully (this is the trickiest part) fish the cable through the hole. Use a long screwdriver or hammer to push the lever up closer to the cable to be able to fish the cable end through the hole. (Be patient as this part is a little tricky - might need the needle nose pliers to slightly bend the cable and it will eventually go through the hole.. Now just reconnect the screw holding the hand release and you are done.
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
