Need to change batteries in my unit and I can't find by manual. I know their is a special way to replace the batteries. Help!
SOURCE: 2000 Jaguar S-Type Battery
I had to change the battery in my 1999 S-Type, you will need the radio code, I also needed to reprogramme the board computer which is easy if you have your manual at hand, also the car might act strangely for a while, but this is explained in your users manual, nothing to worry about.
Hope this helps.
SOURCE: changing spark plugs
pull the wires off and take a spark plug socket with a extention and pull em out
SOURCE: I NEED A SPECIAL TOOL BUT DON'T KNOW WHAT IS IS CALLED
you will need 2 special tools, one is the crankshaft locking tool the other is the camshaft gag or alignment tool
SOURCE: 1998 Buick Riviera battery
Make sure that you have the ventilation tubing when replacing the battery. The car is designed to vent battery gases from beneath the car. Substituting a different type battery (without vent ports, a small hole that is located at each end of the battery ) or if you decide to use the battery without the ventilation tubing, you run the risk of an explosion. This is due to the proximity of the battery to the fuel pump, which is also located beneath the seat.Underhood batteries vent naturally into the air within the engine compartment. In your car there is a small hole in front of your battery that leads to the underside of your car.Your tubing is designed to carry the battery's vapors way and direct it out of your car through this hole.
SOURCE: Changing the Spark Plugs. Do you need a special
There is a special Spark Plug socket for removing plugs. The engine does not have to be moved.
Testimonial: "Information was greatly appreciated. Thnx."
