You are assigned to help mrs.jones with her laundry and vacuuming. When you try to do mrs.jones laundry, she tells you've used to much soap (even though you have used the correct amount, according to
Unhook the water hoses at the wall and check to make sure the screens are free of debris. The pump is easy to access via the back panel--just two screws. There are blogs available that tell you how to check and replace the pump if necessary. Read all of them before you start. It is often the culprit. Good luck.
Solve for x by subtracting 8 from each side and dividing by coefficient in front of variable. Plug answer into original equation to check that it works correctly.
I just want to make sure that you still would like help with your Bissell. As you may see from my profile, when I help someone out, I always spend considerable time answering questions, taking pictures, and really making sure that you know how to fix the problem. Before I spend so much time doing this, I like to follow up and make sure that A. there's a real customer I'm answering, and B. that you haven't already fixed your machine. If you'd like me to walk you through this troubleshooting, please just add a comment here on the repair page.
you NEED to buy real washing soap from a store. I recommend Tide because you may be mixing wrong ingredients or not adding something. If buying new/real soap doesnt work i would go to a sears or email sears at their website and tell them.
Yes it does matter which cleaning solution that you use in your steam cleaner. If you use the wrong cleaning solution it may cause problems with the cleaning solutiondispensary system. Different steam cleaners use different cleaning solutions. You should always use the steam cleaner solution for your specific cleaner. I have learned this the hard (and expensive) way.
Hard to recommend this but it will work in a pinch. You can use a small amount of liquid laundry detergent diluted with hot water (about 2 table spoons to a gallon) as a stand in for the real deal. DO NOT put the laundry soap solution into the cleaning solution reservoir (the wax content will clog the soap dispensary system). Lightly apply to the area to be shampooed (do not soak). I have used a plastic coffee can with holes poked in the lid like a watering can to apply the soap solution. Use the shampooer to do the scrubbing and remove soapy water from the shampooed area. Fill your soap reservoir with clean hot water. The laundry soap does most of its job during the rinse. Go over the shampooed area with the shampooer moderately soaking the shampooed area to with the hot rinse water. Remove as much of the rinse water as possible. Liquid laundry soap has a high wax content (makes your cloths soft) and if it is not rinsed thoroughly after it is dry the remaining wax will attract dirt faster than the surrounding areas. Other than that it works for a good stand in for the properdetergent in a pinch. As a bonus it smells great.
From what I understand as unorthodox as it is, it works well in small doses, and I don't believe that it causes any damage to the other parts of the steam cleaner as steam cleaners survive drawing up worse things into them than laundry soap.
After speaking with someone with trouble shooting experience in these matters, I now believe the problem lies NOT with the washer but with a bad batch of laundry detergent which fails to dissolve properly in the water.
If you have a water softener or very soft water, soap will suds up more than if your water is normal or hard, so you'll need to use less than recommended. Obviously soap breaks down the dirt, but the dirt also breaks down the soap, so if your clothes are not very dirty to start with, you'll need less soap than if they were more dirty. Soap can also be stored in laundry like towels and cleaning rags and when combined with the laundry soap will suds more. You can try raising the leveling legs in the front to tip the washer back. This will help the water drain back into the tub instead of pooling on the boot. You can also try using the 'extra rinse' option. Keep cutting back on how much soap you use until your laundry is not as clean as it should be. You might be surprised how little soap you can use!
Yes you can but remember to only use 2 tablespoons of detergent. It may not say it in the owner's manual but it is what the factory is telling us to relay to the customers.
