RCA 25425RE1 Phone Logo
A
Anonymous Posted on Mar 13, 2014
Set up answering machine and retrieve messages
Retrieve messages
Retrieve deleted message
if you have sync set up on your computer with Kies air they should be in there. If you don't they are gone.
How can I retrieve messages accidentally deleted?
Look for the manual of your AT&T 1725 digital answering machine
1helpful
Need help to retrieve messages from outside
I have a different model but the default code for mine is 123.
To change the code from the machine, I have to press the STOP/SET button and hold it and wait for prompts.
2helpful
How do your retrieve messages from home while away from home
Here's the manual:
29869GE2 Digital Answering Machine
You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
2answers
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Remote message retrieval
When you first installed your GE Digital Messaging System, you heard the code that was auto set for it. Once you are out and away from home, phone home and during the answering machine promp press # and then the promps will ask you for your 'pass word [code]. Please be careful as messages deleted by you, you may not beable to retrieve them. This machine doesn't run by cassette tapes.
~ hope the above helps.
3helpful
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
1helpful
2answers
RETRIEVE MESSAGES
To retrieve a message from another location, dial the telephone number and when the greeting message starts punch in your four digit code. The default code is 0123 if you haven't set one. Follow the prompts to listen to messages.
Deleting messages from AT&T 1738 digital answering machine
Press "3" during the message.
Press "3 twice" after all messages played and you here the two beeps.
How do you retrieve messages from another phone?
If you have not changed the code, it should be set to the default code 1-2-3. Call the phone with the answering machine, and as soon as your greeting starts press 123. You will then hear a menu. Press 1 to retrieve your messages. After listening to your messages, you can listen to the menu again, which will tell you that you can press 0 to delete your messages, among other choices. Cathy
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
