I went to walmart yesterday and everything was fine untill I came out and my truck would not crank. It is turning over but it is not trying to crank. Its like it is not getting a spark. I checked the fuel and everything is good there. I got it to crank after several trys the next day. I made it home in the truck but when I cut it off it would not crank up again. The truck is a 2000 tahoe 4wd 5.7.
"cranking" is turning (comes from when engines needed to be turned with a crank to start them)
So, your vehicle is cranking but not starting. You could do a code scan that would point you in the right directon...It sounds like a bad crankshaft position sensor or coil ..check that.
