Computers & Internet Logo
m
michael phelps Posted on Mar 14, 2014
Error code 401
Cant login
Jaco Morri
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Mar 14, 2014
Jaco Morri
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
946
Points
21
Sounds like you are probably messing up the username and password.
"Generally this error message means you need to log on (enter a valid user ID and password) somewhere first. If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.)."
www checkupdown com status E401 html
RICOH Aficio MP W2401 FUNCTIONAL PROBLEM SC 401
Ricoh Aficio 240W Plotter Error Code SC 401-00
Copytechnet https://www.copytechnet.com > forums > 108927-rico...
May 4, 2016 - On old Ricoh Aficio's SC401 used to be a Transfer error, but on the 240 its ID Sensor, could be dirty, could be old Dev, could be a loose ...
Ricoh MP2352 SC401- Strange problem
Jul 28, 2021
Error Code SC-401
Sep 12, 2014
ricoh mp 3352 - error sc401
Dec 11, 2020
Ricoh mp 2851 SC 401
Jul 11, 2017
More results from www.copytechnet.com
Error Codes > Ricoh > MP2553 > Code SC401
Printcopy.info https://printcopy.info > code=SC401
Code: SC401 Ā· Description: Transfer positive electrode current error A transfer roller current leak signal is detected. Ā· Causes: ā€¢ High voltage supply board set ...
Missing: W2401 ā€Ž' Show results with: W2401
Error Codes > Ricoh > Aficio 2090 > Code SC401
Code: SC401 Ā· Description: Transfer roller open error Ā· Causes: ā€¢ Transfer power pack defective ā€¢ Poor connection between the transfer current terminal and the ...
2answers
How to Resolve QuickBooks Unauthorized Error Code 401?
QuickBooks Error 401 is caused when the user is trying to access the QuickBooks company file, but the login credentials are invalid or incorrect. The error message will typically state "Unauthorized: User authentication failed" or "Access denied: Invalid user ID or password".
Here are some steps that can help you resolve QuickBooks Error 401:
  1. Verify your QuickBooks login credentials: Make sure that you are entering the correct login credentials for your QuickBooks account. If you are not sure, you can reset your password.
  2. Clear cache and cookies: Clear the cache and cookies from your web browser to remove any stored login information. This can help resolve login issues.
  3. Update QuickBooks: Make sure that you are using the latest version of QuickBooks software. An outdated version can cause issues with the software, including login issues.
  4. Check your internet connection: Make sure that your internet connection is stable and working properly. If your internet connection is slow or not working, it can cause login issues.
  5. Disable antivirus or firewall: Sometimes, antivirus or firewall software can interfere with QuickBooks login. Temporarily disable any such software and try logging in again.
If the above steps do not resolve the issue, you may need to contact QuickBooks technical support for further assistance.
2answers
Netbank login
This problem may be caused by a number of reasons. However, the following are the most common:
The users credentials (the username and password) are not correct.
The user account may not have the right to log on to the computer interactively (the "Log On Locally" right). In some scenarios, the user account requires "Log On Locally" right.
Check the username and the password of the user to make sure that they are correct.
If this is correct, be sure the user has the "log on locally" right granted to it.
To verify user rights, do the following:
1. Open the Local Security Policy tool from the Administrative Tools folder.
2. Click Local Policies, click User Rights Assignment, and then click the Log On Locally user right.
If the user account or group that the user belongs to is not listed, then add it.
See the Internet Information Services 5.0 documentation for more information about authentication.
This documentation can be found at the following URL example:
http://localhost/IISHelp
or
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our Check Up Down robot) was correct, but access to the URL resource requires user authentication 1) which has not yet been provided or 2) which has been provided but failed authorization tests.
This is commonly known as "HTTP Basic Authentication".
The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field. (Last updated: March 2012).
Fixing 401 errors - general
Each Web Server manages user authentication in its own way.
A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL.
This person then uses Web server software to set up those users and their passwords.
So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you.
Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem.
The first thing you can do is check your URL via a Web browser.
This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously.
Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to the Web page.
If this type of browser check indicates no authority problems, then it is possible that the Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code.
This is unusual, but may indicate a very defensive security policy around the Web server.
" 401 unauthorised " is the error message i
No, but you can just reset the whole router and start from scratch. Hold the reset button on the rear of the router for 60 seconds and your will restore the unit to defaults, at which point you just need to reconfigure all of your configuration settings and password, as well as your wireless access code. Let me know if you require any additional assistance.
2helpful
I have TP LINK WAIRLESS ROUTER TL-WR642G. I have connected properly, last time i could log in and configure. But now i forgot last password, reset properly the router but cant login by default username and...
You'll need to reset your router if you can't remember the password to get into the settings. There should be a tiny button on the back that you can press with a pen or pencil.
Once it's reset, get on a computer that's connected to the router and type this address into the URL field:
192.168.1.1
This should get you to the settings. If it prompts for a password, try "admin" and leave the field blank.
1helpful
It always said to me error 401
Error 401 means that you can't access a web site. To fully understand the error and how we need to try and help you fix this we need to know what HTTP Error 401 - you are getting.
Example: HTTP Error 401 - Unauthorized: Access is denied due to invalid credentials.
2helpful
2answers
Keep getting a 401 unauthorized code when trying to log in to sur
Your Web server thinks that the HTTP data stream sent by the client (e.g. your Web browser or our CheckUpDown robot) was correct, but access to the URL resource requires user authentication which 1) has not yet been provided or 2) which has been provided but failed authorization tests. This is commonly known as "HTTP Basic Authentication". The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field.
401 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle:
Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
Open an IP socket connection to that IP address.
Write an HTTP data stream through that socket.
Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code it recognises as '401'.
Each Web Server manages user authentication in its own way. A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL. This person then uses Web server software to set up those users and their passwords. So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you. Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem. The first thing you can do is check your URL via a Web browser. This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously. Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to your Web page.
If this type of browser check indicates no authority problems, then it is possible that your Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well-known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code. This is unusual, but may indicate a very defensive security policy around your Web server.
Fixing 401 errors - CheckUpDown
When you set up your CheckUpDown account, you may optionally provide two items 2. Web Site User ID and 3. Web Site Password. You should provide these only if your site uses HTTP Basic Authentication. If you provide them, the CheckUpDown robot always uses them. This will result in a 401 error if in fact your site does not use this authentication. Conversely, if you do not provide them and your site does use this authentication, you also get a 401 error.
If however your URL is open to all comers, then an 401 message should not appear. Because it indicates a fundamental authority problem, we can only resolve this by negotiation with the personnel responsible for security on and around your Web site. These discussions unfortunately may take some time, but can often be amicably resolved.
Alternatively or the other way around is :
open the XP hosts file, and do a manual insert there.
The hosts file is located at: C:\WINDOWS\system32\drivers\etc
The entry is: 192.168.0.1 www.routerlogin.net
You might need to flush your DNS records at this point, or simply restart your computer.
And then use the following URL to access the admin page:
http://www.routerlogin.net/setup.cgi?next_file=start.htm
***Here is another solution to the problem, which is a fairly straight-forward way to disable the annoying wizard.
Type in your browser:
http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
1helpful
When faxing a 401 error is reported
error 401 means that your number is not programed in the machine you are trying to , so it blocks it
Top Facebook Computers & Internet Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
