RCA D52W19 52" Rear Projection Television Logo
Posted on Mar 14, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The green crt on my rca tv has light but no picture inside. i changed fluid. still same. the red and blue have crystal clear pictures. also makes a real fast clicking noise and takes five miutes to come on. its 11 years old
  • dflint1009 Mar 14, 2014
    also, convergence works fine. looking into the green tube there are no images at all. it is blank like it is getting no tv signal. just green light.
Level 3:
  • RCA Master 19,187 Answers
  • Posted on Mar 14, 2014
RCA Master
Level 3:
Answers
19187
Questions
0
Helped
4345552
Points
82261
The problem is the driver for the green tube. Without test equipment this could be hard to track down. Also the fluid is just to keep those high intensity tubes from overheating.
5 Related Answers
mbranjo
  • Posted on Jun 09, 2008
SOURCE: distorted picture on RCA LCD TV
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Anonymous
  • 1030 Answers
  • Posted on Jun 21, 2008
SOURCE: Red,Blue,Green Image
YOu have convergence issues. Ok first question. IN your setup menu do you have the convergence option/ if you DO not then it can be a specail fusable link. fl231 if you do. next question do the picture bow in at the middle. if you do then it possibly a convergence power supply issue. next if you go into setup convergence does the crosshairs adjust up or down left to right on both blue and red. I if so then theres is a chance that it can be a convergence adjusment or a amplifer problem AS always THIS SET CAN GENERATE LEATHAL 380 VOLTS EVEN WITH SET UPLUGED SO BE CAREFULL.
Anonymous
  • 1139 Answers
  • Posted on Jun 09, 2009
SOURCE: Hi I have a 52
Hello clara7,
This denotes a convergence problem. I would suggest that first you enter the menu of your TV ad try to do an auto converge on your set, if this does not work I would suspect that the convergence ICs have gone bad and need to be replaced. I would suggest that you have a qualified TV repair technician replace the convergence ICs in this set.I hope this helps,Shuttle83http://www.electron-age-technologies-llc.com
Chi Chu
  • 8457 Answers
  • Posted on Sep 08, 2009
SOURCE: I have a 3-yr old RCA HD61W66 projection TV that
The cost about $300 parts and labors.U can do the repair ur self about $100,but require ordering the parts in the net.Must take the tv aparts.Have to desolder the parts,put in the parts correctly and resolder it.This website for the Net ordering parts.Tv Repair World.com.
Anonymous
  • 51 Answers
  • Posted on Aug 30, 2010
SOURCE: MY RCA MODEL R52WH74 YEAR
What you most likely have is a convergence problem. The convergence circuitry is used to align your colors. What you describe sounds like that circuit has failed. Here’s a link to a decent video that will give you an idea of what is needed to fix it: http://www.youtube.com/watch?v=S6Wa8FvSz-s
I turn the tv on and it comes threw with a fogy green and red picture with very little blue. there was dust on the lens and i cleaned them but and all the lights light up but still the green and red. i...
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
2answers
AFTER CLEANING BOTH THE MIRROR AND THE THREE LIGHTS MY PICTURE IS MUCH BETTER. HOWEVER STILL NOT AS CLEAR AS WHEN NEW. WHILE I HAVE THE BACK COVER OFF & THE TV ON , THE BLUE AND RED LIGHTS ARE CLEAR...
Picture are blurry and have a hollow effect?But Convergence pictures R,G,B colors lines are all alignments up?Need CRT coolant replacement for the green CRT TUBE gun.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a CRT coolant kit for the replacement.
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
1helpful
2answers
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
2helpful
2answers
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
1helpful
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
1helpful
2answers
Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
