On an incline higher than 5, I hear a banging nose of metal on metal when pressing down with my left foot. I can't figure out if it's the lift mechanism or the ramp....
INcline it all the way up and look underneath the ramp. Check where the ramp attaches to the main frame. If there are cracks in the bottom of the ramp, you need a new ramp, especially if you have a steel ramp as opposed to alumunum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
