How do I change the setting from KG (currently showing) to LBS on my Weight Watchers scale, model # WW41. The scale did not have any instructions whatsoever (?!). Thank you.
It is possible to switch the weight measurement on a BlueTooth Weight Watchers scale, Model WW941R, from kilograms to pounds through the use of the Weight Watchers app. To do this, follow these steps:
Download and install the Weight Watchers app on your smartphone or tablet. Open the app and sign in to your Weight Watchers account. Tap on the menu icon in the top left corner of the app. Tap on "My Account" and then tap on "My Devices." Select your BlueTooth scale from the list of devices. Tap on "Device Settings" and then tap on "Units of Measurement." Select "Pounds" as the unit of measurement. As for the BT name, it is possible that the BlueTooth name of your scale is "WW941R." You can try searching for this name when pairing your scale with the Weight Watchers app or another BlueTooth device. If the name is not displayed or if you are unable to pair the scale, it is recommended to consult the user manual for your specific scale model or contact the manufacturer for further assistance.
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626. Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
