The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
at the spout near the base is an echeion ring. turn this counterclock wise then pull up ring to expose the neck,pull spout straight up.this echeion cap holds on the spout to the base there are plastic parts inside so be careful when pulling apart.
If it is leaking around the handle, the cartridge may be loose and you need to tighten it more. If it is leaking from the spout, the cartridge is faulty. Even if you bought a new one, it may be faulty. They are made in China and the quality control is awful.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
