SanDisk Sansa e260 MP3 Player Logo
A
Anonymous Posted on Mar 12, 2014
I have plenty of memory for an update but up dater say i don't have the memory
1helpful
1helpful
I bought a second hand nuvi 1310 about a year ago, and now the unit is saying it needs map updates and updates for speed cameras. Where can I obtain these updates?
The manufacturer offers updates at their website. Here is the link for the update page: http://www8.garmin.com/updatemaps/
You'll need to plug your Nuvi into your PC (it uses a mini-USB to USB data cable), and the website detects which unit you have and which updates are available for it. You'll have to download "MyGarmin Agent" and/or Garmin's Communicator Plugin first, if you don't already have them installed on your computer. It's a good idea to have a MicroSD card plugged into your Nuvi before connecting it to your PC (The Nuvi and the memory card each show up as removable drives in My Computer). Otherwise, if the unit is too low on memory when you attempt to update, you'll either have to get a MicroSD card to expand the available memory, or deal with reduced map data coverage.
Unfortunately, I don't believe the updates are going to be free for you -- Garmin has very specific conditions in order to qualify for an update at no charge. Don't quote me on that, though.... Not knowing all the specifics on your unit or it's purchase, I can't say for sure. I'll keep my fingers crossed for ya.
Good luck
13helpful
2answers
I cannot put the two pieces of my received versadater stamp together and my stamp did not come with instructions....
I worked for a company that sold these stamps. Xstamper made some changes to this stamp & in doing so, the dater part would no longer attach to the received piece. Contact the company you purchased this from. Xstamper fixed our problem by going back to their older model so the two pieces would join together.
1helpful
3110c
got this from the net, maybe it helps:
The Problem with Nokia 3110c – Switching off and automatically restartingThis is what happens. Nokia 3110 hangs, gets switched off andrestarts randomly. More often, it restarts around 3 times or so andthen gets switched off.
Possible Causes and SolutionsCause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500KB, so as to keep things running smoothly on your phone and preventNokia 3110c from restarting.
Cause 2 – Changing Themes – Some people havereported that the phone restarts automatically when they try changingdisplay themes on the phone.
Solution – Don’t get your phone loaded with toomany themes downloaded from the internet or atleast, don’t switchthemes frequently. These themes, mind you, also load up things intoyour already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB datacable (or) Updating Music Library – A few people have reported thattheir Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but considerconverting all your MP3 music files to WMA and then store them on thememory card. Some users suggested this.
Disclaimer – Follow the suggested solutions at your own risk. The author is not responsible for any damage caused to your phone.
UPDATE:IT LOOKS LIKE A FIRMWARE UPDATE COULD FIX SUCH NOKIA 3110CRESTARTING PROBLEMS – RESOLVE YOUR ISSUES RIGHT NOW BY UPDATING YOURNOKIA 3110C FIRMWARE – CLICK HERE TO KNOW HOW YOU CAN UPDATE YOUR NOKIA PHONE FIRMWARE
Jul 23, 2009 • Nokia 7610
How to flash my n73 nokia mobile
you have flasher if no to download Nokia software up[dater and connect your phone with pc and update your phone software that's all
My gps 12 haS PROBLEM IT SAYS ( UPLOAD NOT PRESENT , WHAT IS THE SOLUTION ?
Go and grab a garmin serial lead from somewhere and go to the following link and download the VER4.6 software.
http://www8.garmin.com/support/collection.jsp?product=010-00146-00
The Garmin web dater may not work because the unit may already have had Ver 4.6. If it does then the web updater will tell you that you already have the latest verson on your unit and won't proceed any further.
You need to download the 4.6 updater by itself.
Hope this helps
Alan
6helpful
2answers
Automatic restarting problem with Nokia 3110c mobile phone
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Solution - Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 - Changing Themes - Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution - Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 - Memory Cards - Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution - Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 - Transferring data via Blueooth / USB data cable (or) Updating Music Library - A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution - Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 - MP3 files
Solution - This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Software problem of nokia6280
i have nokia 6280 having display problem
12helpful
4answers
Formatting internal memory of nokia 3110c
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Possible Causes and Solutions Cause 1 - Phone Memory Full - Nokia 3110c mobile phone has got 9MB of internal memory.
Cause 5 - MP3 files
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
