Texas Instruments TI-15 Explorer Calculator Logo
A
Anonymous Posted on Mar 12, 2014
What does pi equal - Texas Instruments TI-15 Explorer Calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Apr 15, 2014
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428435
Points
622693
It's the ratio of the circumference of a circle to its diameter and is about 3.14159.
See http://en.wikipedia.org/wiki/Pi
What is the diameter of a circle with the perimeter of 5.14
1.64 ( C=pi D circumference is equal to pi times the Diameter. Diameter is equal to the circumference divided by pi. pi is 3.14. 5.14 divided by 3.14 is 1.64.)
2answers
How many cubic yards would it take to fill in. 20' x 2' diameter
Hi Paula:
A mathematical logic question.
You need to get all of the measurements in the same units.
- A cubic yard is 1 yard x 1 yard x 1 yard
- equals 3 ft x 3 ft x 3 ft
- equals 27 cubic feet,
so once you have the volume of the pipe in cubic feet, you divide by 27 to get the volume in cubic yards.
- Volume of a cylinder (the pipe) is the cross sectional area X length.
- Area equals Pi x r squared.
- equals 22/7 x 1 x 1
equals 3.14#####
times length (20)
equals 62.857### cubic feet volume
divide by 27 cubic feet
equals 2.328### cubic yards.
- The answer is always the easy part.
- what is important is knowing exactly what the question is, and
- determing what calculations are needed to get the answer.
Wasn't that better than if I'd just said 2 1/3 cubic yards?
Cheers
2helpful
2answers
15" circle what is outside measurement
If you would like to know the circumference of a 15" diameter circle this is the formula:
circumference = radius x 2 x pi
circumference = diameter x pi
in our case:
circumference = 15" x 3,14
circumference = 47 ,1" (that's 119,634 cm)
Finding pi
hi
look for the pi key it should be there or type
sin(180/1000000)*1000000 press enter or equal key to get 3.141592654 for a result it the same value as pj on the pi key times it by 3 to get
9.424777961 for a result.
hope this helps
I can not graph a parametric equation useing radians. I am using a TI-nsipre with out any updates since purchase not a CAS or CX one.
In parametric functions, the variables x and y are both functions of an independent variable, called t, and that usually represents the time. The default variable in parametric functions must be called t. You can enter the limits you want. However if you type in 2 Pi it will be converted on the entry line to 6.28. The default tstep is 0.13 which is about pi/24. I fail to see what the commotion is about.
In this representation of the witch of Agnesi, the variable t is between 0 and 4Pi, and the step tstep is 0.13, a little less that pi/24
Reset your calculator and restart
How do i solve and what is 2 to the power of Pi equal to
Press 2 ^ 2ND ^ ENTER .
If you get a symbolic result, press diamond ENTER .
Convert -525 degrees into radain pi form
Here is some help
180deg is equivalent to Pi radians
Take some angle. Its measure in degrees is say x_deg, Its measure expressed in radians is x_rad.
The fraction of 180 deg that the angle represents is equal to the fraction of PI that this angle represents.
Conclusion: the ratio x_deg/ 180 deg must be equal to the ratio of x_rad/PI
x_deg/180 deg=x_rad/PI
Isolate X-rad in the above equation. Some will tell you to cross multiply.
x_rad=(Pi/180)*x_deg
Application: x_deg=-525 in radians?
x_rad= (PI/180)*(-525)=-(525/180)*PI
Keep the value (525/180) as a fraction reduced to its simplest form. The result is 35/12
2answers
What is the pi button
Pi is a mathematical constant whose value is the ratio of any Euclidean plane circle's circumference to its diameter; this is the same value as the ratio of a circle's area to the square of its radius. It is approximately equal to 3.14159265 in the usual decimal notation.
5helpful
2answers
How do you graph y = the inverse contangent of x?
The cotangent function is not implemented on the TI84PLUS native OS and consequently you will not find its inverse function on the calculator. However, there exits an equivalence (definition) between arc cotangent(x) and arc tangent (1/x).
Thus cot^(-1)(X)= tan^(-1)(1/X),
Be careful. Since it is a multivariate function, some authors define the principal branch in the domain [0, PI], while others define the domain on [-Pi/2, Pi/2]. You will have to consult your textbook, or the documents you are using to find out the domain of the principal branch.
What is the area of a semi circle the diameter is 2.500mm the radious is .425mm the circumfrence is 3000mm
You cannot have a semicircle that has a diameter of 2.500 mm and a radius of .425mm and a circumference of 3000mm
Circumference is equal to pi times the diameter. pi is = 3.14
The radius of a circle is always 1/2 the diameter
Area of a circle is pi time the radius squared
Loringh
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
