How do I open the scanner to clean the under side of the scanner glass how to take the glass out to clean both sides and replace
I recommend you do not take off the glass. I have done it and was never able to get rid of the dust, which really shows up on every scan. The fogging has something to do with an optical coating on the underside of the glass. If I knew then what I know now, I would let it be. If the fogging doesn't show up in scans, leave it. If it really does show up, the glass itself is often held down by simple double stick tape. You try to keep the tape intact so you can put it back down. It may be strong enough that the plastic frame on top of it could snap. Do it in as clean (not dusty) environment as possible so dust does not drift down inside the scanner. Never touch the lamp or move the scan mechanism. Again, don't do it unless it's showing up on scan results. Sadly, nobody "fixes" scanners, they are disposable, like coffee pots, even if they cost 300.00.
SOURCE: cleaning
Unfortunately, cleaning dirt or debris from under the glass requires disassembly of the scanner and must be done by an Authorized Epson Servicer. Please refer to the Epson Customer Care Centers. if its still within the warranty period call epson.
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
SOURCE: scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
SOURCE: The inside of the glass needs to be cleaned. How
The 3170 has a screw in each of the two slots where the lid inserts into the scanner. Remove the lid, remove these screws, and then the top portion of the scanner with the glass slides forward and off. Mine was stiff getting it off, but with some slight twisting and a bit of force it came off. You can then clean the glass.
