The machine started by jamming paper then suddenly it started to complain about the fuser unit, all the four drums and it does not boot to finish.
Remove all consumables, turn off and leave off for 10 secs, turn on allow the machine to turn over at which point it will ask you to install the consumables, - install 1 at a time then close the doors , allow the machine tostep further and ask you again to install the next unit- this process will change when you get the faulty unit and try to insert, the machine will complain about all the consumables again- now you knowwhich part is faulty- replace -job done
hi im jules_09.have you reassemble the fuser correctly?check again the inside of the machine for small pieces of paper its just there the machine wont flash the misfed if there is nothing stock in the machine.although sometimes the drum can cause the misfed,try to full out the drum.it cant be stock just see if the drum is rotating try to rotate it 360 then slowly full it out,also check if there are srews where the drum process unit is at
