Hi William Dunsten, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Did you try and charge it?Hi William Dunsten, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Did you try and charge it?
You can't post conmments that contain an email address.
Re: I have a tablet that wont turn on. It shows a dead...
Can the tablet turn when plug in to ac adapter/ home wall charger?
Maybe I can help you if you can tell me the model of your tablet.
EZBUY batteries and chargers laptop batteries
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
Check the output of the charger to make sure its actually working, if it is most likely the battery connector inside the unit is bad, or the battery is bad.
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Can mean the battery isn't communicating its status to the tablet--failing battery, bad connection, etc. Talk to tech support for a replacement if it's still under warranty. If it's not and you can still charge it to 100%, hang on and hope for the best.
A triangle with an ! in it usually means that it's operating system has been rooted. Is it second hand if so the previous owner has been playing around with it and the warranty is void.It can be wiped and reinstalled, but you need to know what you are doing, there are instructions and videos on u tube showing how it's done.
my ipad wont turn on it like when you press the home button it lights but you cant see a thing I don't know what to do with it it wont come on if you have a answer to this problem please I need your answer right away. Thanks
The exclamation mark means that your tablet has no battery left. You should try plugging your tablet in for a few hours before turning it on (if it doesn't turn on by itself.) If that doesn't work and you still see the exclamation mark, I suggest that you ensure the charger is properly plugged in to the socket and that its properly attached to the tablet.
