HAVE KEY #2012 BUT NO MANUAL
If
the remote s faulty then key fob will not get programmed.
Insert
the key in ignition. Turn the key to on position, and cycle the key three times
off-on-off-on-off-on. Then with the key fob remote select your remote and then
try to operate the vehicle with remote.
These
are just the basic procedure, but sometimes it will not help.
On
that case dealer is the only option.
There
are few much related troubleshooting links mentioned below for remote key fob reprogramming.
I suggest you to go through the list and click the link below to go through its
details and procedure: -------
http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html
http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html
http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html
http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html
http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html
http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These
details will help.
Thanks.
KEYFOB PROGRAMMING
If
Insert
These
On
There
These
details will help.
Thanks.
