Question about Vivitar ViviCam 3765 Digital Camera
There is no setting on my camera called date stamp how do i turn on the date stamp so that it appears on the photo
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Posted on Aug 08, 2012
SOURCE:
  • 203 Answers
SOURCE: I AM TRYING TO SET THE DATE & TIME TO APPEAR ON MY PHOTOS.
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Posted on Jun 02, 2008
dlundmark
  • 797 Answers
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
Posted on Jul 19, 2008
SOURCE: getting date & time to appear on myu photos
I have a sony DSC-T70 and cannot figure out how to add date and time stamp to pictures taken???
Posted on Nov 02, 2008
old marine
  • 2254 Answers
SOURCE: date time stamp
The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
Posted on Sep 08, 2009
Testimonial: "Fantastic! I've been trying to sort this out for ages, and that has done the trick! Cheers :) "
welcomejee
  • 10594 Answers
SOURCE: I just purchased an Olympus
Olympus Stylus Tough 3000 prints date on image if you connect it directly with printer to get print out of pictures. Printer must have PictBridge mark to receive picture data directly from camera. Usually this type of printer calls photo printer.
Olympus Stylus Tough 3000 does not show time/ date stamp in picture files either in camera playback or transferred in computer. It only prints date info while printing photos through photo printer.
Connect camera with printer and select Custom Print in setup/ print mode, you will see Date option (with/without) to get photo printout with desired info.
Above info also available in user manual, check page-54 fro more details. Click HERE to download related user manual free copy.
Hope these info will help you.
Thanks.
Posted on Oct 30, 2010
Would like to know how to insert the time and date stamp onto the Canon A710IS please. Thank you
Download any manual about this product by visiting the link bellow. hope it what you looking for.
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a710_is#BrochuresAndManuals
Thanks for using fixya,
May 16, 2011 | Cameras
I have a Canon SX30. I happened to turn on the Date/Time and now apparently ALL the photos have this imbedded in them. The date and time appear in the photo when I view them on my computer. I had...
The date time stamp is permanent. Once its set and you take a picture it will stay on it even if you turn the time stamp off in the camera (this will prevent it from occurring to future pictures).
To remove it from the pictures you already have you can either crop the image so that the stamp no longer appears in the frame you want, or use a clone or blur tool in an image editing program to erase the stamp.
To turn it off in your model, press menu, use the side to side arrows to select the camera tab, then use the up or down arrows to select date stamp.
Use the left or right arrows to chose off instead of date or date and time.
Please leave feedback if this was helpful. Thanks.
Mar 25, 2011 | Canon PowerShot SX30 IS Digital Camera
I have a Panasonic Lumix DMC-FX520 and the date stamp wont appear on printed photos. The date shows when I take the photo,how do I get the datestamp to show up afterwards
Normally in the menu settings the options are entered so as to stamp the date in. So open menu settings and check on clock and date settings. check for links to date stamping in the menu and activate.
Sep 24, 2010 | Cameras
Can anyone tell me how to get the date to appear on my photos using a Canon Ixus 70 camera?
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
Nov 01, 2009 | Canon Cameras
Date stamp will not appear on photo. i was told that there is on/off setting for this in the general setup menu called "date stamp" however,the model "vivicam 3765" has no such setting. how do i get the...
Jun 13, 2009 | Vivitar ViviCam 3765 Digital Camera
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
Date to appear on photo
Set the image size to 'postcard'. Press the Function key, scroll down to the bottom icon and select postcard (L, M1, M2, S, postcard). Press Function key again.
To turn the date imprint on, go to the Record menu and set the option for Date Stamp to Date or Date & Time.
Jan 06, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
Date stamp on photos for Canon SD100 IS
I believe you are referring to the PowerShot SX100 IS, as there is no SD100 IS. And yes, it does have the date stamp option while the image size is set to the postcard mode.
Jan 05, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Date stamp on photo
Check the options carefully, and read the manual.If you don't have a manual, they are free for the download at Sony. Look for you camera under support/downloads.
Some cameras only allow date and time stamp to be in certain resolution settings. It will not show up in other photo size settings.
Jun 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
How to do it:
Use the func. set.
Dec 13, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Vivitar ViviCam 3765 Digital Camera Logo
54 people viewed this question
Top Vivitar Cameras Experts
Ekse
Damen Wong
Damen Wong
Jeffrey Groves
Jeffrey Groves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
