Dishwashers Logo
B
Brigitte Burridge Posted on Mar 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E1 message on my LG Inverter Direct Drive Dishwasher
E1 message showing. Can not clear message, or turn off power on dishwasher. Flooding occurred after twins sinks were accidently left full of water.
Carmen Mikulic
Level 2:
Sergeant:
  • Expert 415 Answers
  • Posted on Mar 12, 2014
Carmen Mikulic
Expert
Level 2:
Sergeant:
Answers
415
Questions
0
Helped
217493
Points
909
An F1 usually means a communication error between the control board/touchpad and the motor/pump assy. Could you please supply the full model # for your unit?
5 Related Answers
Anonymous
  • 121 Answers
  • Posted on Nov 07, 2007
SOURCE: water build up in dishwasher- clogged drain
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
Anonymous
  • 35 Answers
  • Posted on Jan 16, 2008
SOURCE: broken dishwasher
If there is no water in the dishwasher - i.e. it had finished a cycle, but now it is just the indicator lights that are on, then the chances are some water has got into the control system. It will probably dry out, given time. (maybe a number of days.)
If there is water in the dishwasher -i.e. it was part way through the cycle and stopped, it maybe that the outlet hose/pipe has got blocked - possibly by your plumber's efforts. Generally speaking, the fats are rinsed off by the hot water, but go solid further along the pipes, as it cools. It could be he has unblocked the sink drain side of things, but not the dishwasher drain pipe. Risking more water on the floor, if your flexible waste hose can be removed, pour some water down the waste pipe, see if it goes away fast enough.
One thing worth trying, if not done so, is to unplug it from the supply, and leave unplugged for 20 minutes or so. Then plug it in and see if it operates OK then. Maybe try that first.
A
Anonymous
  • Posted on Mar 25, 2008
SOURCE: LG dishwasher
I bought a stainless steel Lg less than 15 months ago for 800.00and it stopped working. The manufacture said so sorry even though you didn't take delivery until the end of Jan. your warranty goes by purchase date. I would of been better of with a maytag.
Jeff Meyer
  • 423 Answers
  • Posted on Mar 30, 2009
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
Anonymous
  • Posted on Jun 03, 2011
SOURCE: Hi Kenwood dishwasher kdw60x10 -
I have the same problem :( e1 fault and full of water, I have check pressure and drain for blockages too.
My LG intello dishwasher LD2050SH gives me an E1 error
AE & E1 ERROR CODE - DISH WASHER
LG Electronics https://www.lg.com > support > help-library > ae-e1-er...
Nov 8, 2023 - An AE or E1 error code means you have a leak inside your dishwasher activating the float switch. Before you can start using your dishwasher ...
Missing: LD2050SH ‎' Show results with: LD2050SH
Help library: AE & E1 error code - Dishwasher
LG Electronics https://www.lg.com > Home > Support > Troubleshoot
Dec 13, 2023 - The AE or E1 error code indicates a possible leak from the unit. ... Then run an empty cycle with nothing in it to clean out the dishwasher. If ...
Missing: intello ‎ LD2050SH
LG Dishwasher - Error Code List ' LG USA Support
LG Electronics https://www.lg.com > support > help-library > lg-dish...
Jun 20, 2023 - If overfilling occurs, the flow switch will trigger an E1 error code and your dishwasher will turn off to prevent outside leakage.
2answers
Delonghi Dishwasher
Can you please tell us the exact model of your dishwasher? What you can try initially is unplug the power cable of your unit for about 10 minutes, then plug it back in. See if that clears the error. Will give you follow up about the E1 error.
2answers
LG dishwasher LD2080TH Error code: E1
LG has programmed in the E1 error code to indicate when the drain pump is running, it is not receiving the back pressure it needs. This is most likely an indication that there is a water leak in the draining system.
https://removeandreplace.com/2017/03/06/lg-dishwasher-error-code-e1-how-to-clear/
LG Inverter Direct Drive dishwasher panel display has 3 illuminated dashes (---). Seems it has power, but won't start. Have waited an hour; dishwasher won't start and dashes won't go away.
I believe the time displays based on your selection. If you don't see any change when changing selection it may be a faulty touch panel.
Assuming you tried resetting the whole unit. Sounds like program error in the main board.
2answers
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 • Dishwashers
2helpful
From the start, the dishwasher is showing an erroe message: "E1" signal. I would like to see if I can fix it myself.
Hi amloots,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
I have a freestanding LG dishwasher and the E1 error message has come up. How do I fix it?
The E1 ERROR mean's your main wash motor is clogged or failed & you need to pull it apart completley to test or clear the blockage.Generally its just clogged so get a lg service guy to do it cause he will know your dishwasher inside out.THANKS, ECO KIZZA
2answers
Hope this helps!
Lds 5811ww dishwasher e1
LG have a history of E1 error problems.
The controller board can be one cause, however, most of these are caused by a faulty circulation pump.
The impeller breaks on the shaft and does not turn, so it doesn't produce pressure. A pressure sensor activates, bringing up the 'E1" message.
The impeller and pump are a complete assembly.
Replacing it usually fixes the problem.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
