I have konica 1216 error j 11 plz solve problems what i do sir
Replace the developer and the drum and have the tech clean all around the drum area and the sensors
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
SOURCE: in what meaning of konica 1216 copier mechine
fuser code have to have it reset via service mode. its a legacy konica machine.
SOURCE: P26 on screen of Konica 1216 copier. Can you help
the right solution to P26 error reset is mode 47 --> and pressing 5 and 1 key's....you must to wait 2 to 5 min,.for developer initialization....
SOURCE: how to clear f-326-3 code on a Konica 7035
Turn off then on wait 10 seconds between
SOURCE: f28 code problem
generally a dampness problem in the transfer seperation coroner to reset fault, turn of machine hold down 2 and 5 and turn on release 2 and 5 key in P then 4 then 5 then P then 0 then 0 then the green copy buttton then turn off then on should warm up if faults again when you try to copy I think you will need a technician hope this helps :)
