Let the light reset itself. When the engine trouble has been fixed, a Chrysler engine resets the "Check Engine" light automatically after 40 successful runs. If it doesn't reset, the problem likely still exists.
Force the computer into "Successful Run" mode. Start the Chrysler and drive forward a few feet, then put it in reverse and go backward a few feet. Do this three times and shut the engine off. Crank it again to see if the light has been on.
Disconnect the battery for several minutes. This resets everything in the vehicle, including the clock and radio settings. Reapply the radio settings and adjust the time when the battery is reconnected.
Use a diagnostic scanner to clear the codes. Connect the scanner to the test port, also called the ALDL (Assembly Line Diagnostic Link) usually located under the dash (see Resources section). Turn the engine "On" and follow the prompts on the scanner to pull the engine codes. Select the option to clear them.
If you are 6 feet or shorter, than the rope should be 9 feet long. This is the standard jump rope size found in stores. If you are over 6 feet then you'll need a 10 foot rope. Generally, when you hold the rope and stand on the middle with your feet, each end should reach your arm pit.
