Golly, I'm so backward, this is my 4th attempt to get this posted, hopefully, my last. But, one of my problems is, when I try starting Windows Defender, manually, it tells me this program is turned off, and if I am running something else, use action center, to check its status. If I want to turn WD on, click here to turn on. I do, and after a while, finally, windows features, comes back with, this program has stopped, as if I didn't know that, but anyway, that I can start service manually, or I can restart PC, which will start the service. error code: 0x800106ba Well I tried, it didn't start up. I tried 3 diferent restore points, every time it came back with WD still, turned off. I used task mgr. and its thing was that, WD, can't be started because service depends on following systems components, I think referring to RPC, remote procedure call, DCOM, SERVICE PROCESS LAUNCHER, and RPCC, endpoint mapper. rediculous, and I am too! It's 2:54 am. help! If you have any suggestions, try to make it simple, if possible, you know what I mean? 3:20 now thanks
Try to uninstall any other antivirus from you system if exist.
Good Luck
Testimonial: "the only other antivirus I have is norton but its been stopped for at least, a couple of years"
Let me explain, There might be some component of Norton Anti-virus which is causing issue, Try to remove it by using removal tool.
Here is the link for that tool which will remove every component of Norton ->https://support.norton.com/sp/en/in/home...
I did use the the tool, but I still have the same problem, unable to turn windows defender on. sorry to take so long to respond, but I have not been on this PC to check the removal tool to see if would help, ty
