I found this information, copied it from the Vista Forums, but the post was copied from Creative's site .... so its 3rd hand information, at best!
(from the Creative forums - I just copied/pasted - jh)
For those of you with live 5.1 problems, here you go!! Worked for me!
From the post @ http://neosmart.net/blog/archives/104:
Creative Sound Blaster Live! Series
This applies to all Live! products, including OEM Dell, Gateway, HP,
etc. editions, 24-bit, 5.1, and the rest. Vista 5308 may or may not
find drivers on Windows Update, but even if it does, they will not
support Digital Audio.
1. Grab the ngoHQ modded drivers from
http://www.ngohq.com/home.php?page=Files&a...e&dwn_id=20
2. Run the installer in XP compatibility mode.
3. Restart your computer.
4. In the audio properties in the Control Panel, to enable digital audio go to the Other tab and check digital output.
5. Play with the Format tab to get the audio quality to your liking.
6. You may need to restart to ensure that digital audio works after changing that option.
I'm
not 100% sure if creative is going to be upset that I posted this, but
since they have no plans to support the card in Vista, I can't see a
big problem with it.
BTW, I tried the KX driver and I couldn't get it to work, so for anyone with that problem this should be your solution.
I need driver cerative labs model:sb0680 made in malaysia
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight. http://download.cnet.com/sound-blaster-pci128-drivers/3000-2120_4-10038063.html This is an updated driver release for Creative Sound Blaster PCI128 for Windows NT only http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.html The driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added.
http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmln This update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
I'm download file driver ngocmd.exe and run ngocmd.exe but Windows 7 Error Blue Screen (Dumping Physical Memory) after restart Windows. I need help??
I download file driver ngocmd.exe and run ngocmd.exe but Windows 7 Error Blue Screen (Dumping Physical Memory) after restart Windows. I don't know error. I need help??
