Yahoo Mail Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I log on to Internet Explorer my server and when Iget ATT home page, I cannot access my e mail I can't give you e mail address because what is the use. Can't access my e mail and cannot get support
Ian White
Level 2:
  • Expert 147 Answers
  • Posted on Sep 17, 2009
Ian White
Expert
Level 2:
Answers
147
Questions
Helped
29583
Points
397
Open another e-mail account with Googlemail. https://www.google.com/accounts/ServiceLogin?service=mail&passive=true&rm=false&continue=http%3A%2F%2Fmail.google.com%2Fmail%2F%3Fui%3Dhtml%26zy%3Dl&bsv=zpwhtygjntrz&scc=1&ltmpl=default&ltmplcache=2&hl=en-GB When you have succesfully done this go to "Settings", Accounts and Import" and press the "Import Mail and Contacts" button. Enter your old address here and press "Import". This will bring your old e-mail into Googlemail and will continue to do so. you can also set Google up to send e-mail from your old e-mail address! - From Google! This will keep you in communication thro' your old e-mail location until you resolve the home page problem. I would un-install ATT after setting up google as above and re-install it! Hope this helps! Ian.
3answers
After I load a page ...message says explorer not responding and generally computer has slowed down loading pages,etc
i think there is the problem with internet explorer. please update it and try again or uninstall and try to install again
Windows Internet Explorer Errors on this webpage may cause it to work incorrectly
Internet Explorer users may experience frustration when the Internet browser displays an error code, especially if the error causes them to lose work or data.
However, many error codes can give insight into why the problem occurred and how it can be prevented it in the future.
Errors
Internet Explorer may display HTTP status code errors if it cannot display the webpage.
There are five classes of status codes that begin with the numbers 1 through 5. Each status code consists of three digits. 4xx describes client (user) errors.
4xx error codes include:
400 Bad File Request denotes inccorect web address syntax such as improper punctuation or capitalization.
401 Unauthorized denotes incorrect credentials (username and password). Users can attempt to access the page with different credentials.
403 Forbidden/Access Denied occurs when the server blocks access. The website owner may have instructed the server to block access to specific files or directories.
404 File Not Found denotes a missing webpage/file. This occurs when another site uses an incorrect link or the user incorrectly enters the website URL. Double check the address.
408 Request Timeout denotes that the the user or
user's computer stopped the request before the server could complete it.
According to Marc Liron, whom Microsoft has award the Most
Valuable Professional (MVP) award for his technical knowledge and community support, the 408 error can occur because the "user will either hit the stop button, close the browser, or click on a link before the page loads." Refresh the page to correct the issue.
5xx Errors b> Unlike 4xx status codes, 5xx status codes describe errors caused by the server that houses the webpage or file the user wants to access.
5xx errors include:
500 Internal Error denotes a server configuration issue. The error page may instruct the user to contact the website administrator and may provide a contact e-mail as well as additional information about the error.
501 Not Implemented denotes the server's inability to perform the request.
503 Service Unavailable denotes a temporary server status. The server may be overloaded or down for maintenance. Other Errors b> Internet Explorer may display a prompt that alerts the user of a javascript error or display a small triangle with an exclamation point (!) in the status bar at the bottom of the screen.
According to the UpdateXP website, Internet Explorer may display a "52 Runtime Error." http://www.updatexp.com/internet-explorer-error-messages.html This occurs because a javascript cannot find a file it requires. http://www.mediacollege.com/internet/javascript/basic/error.html You may be able to solve this issue by clearing your Internet cache.
Javascripts may also experience syntax errors when the website developed has made a mistake when writing the javascript. Website visitors typically cannot fix syntax errors because the website owner must edit the javascript. However, you can look for a way to contact the website owner to alert him or her of the issue.
2helpful
Mail inbox
In internet explorer you have click on yes when you are prompted from mail to access secure browsing.
This will let you to mail.
I want to have att as my homepage when i log on to my computer.
Assuming that you're using Internet Explorer as your default browser.
1. Open Internet Explorer.
2. Click tools (located at the right pane)
3. go to internet options.
4. At the home page box -- type in your desire web address i.e. www.yahoo.com, www.att.com etc.,
1helpful
Windows 2003 SBS Standard Edition ? IP Address: 192.168.1.5 Linksys WRV210 ? 192.168.1.1 Screenshot Router setup page: http://img205.imageshack.us/img205/3889/capture1w.jpg I have setup a preferred...
hello, is your server 2003 setup as DNS server??? if so have you configured forwarder for non- local access? is that a home? or business? is it work do you not have a static public IP address.
here whats happening, when you manually give client the DNS they can resolve everything local fine but when a request for outside world is sent your server doesn't know what to do with it. log on to server open up your dns console, right click on your domain, then select properties, find forwarder tab and add a any reliable public DNS server there ( ie I use 4.2.2.1 (att)) server pretty quick and reliable.
so next time a request is sent to your server and server doesn't have that information it forward that to the public DNS and you will be good to go.
but from your setup i am gathering there is plently you do to improve your network and reduce your headache of manual work.
typical setup: 1- setup DNS with forwarder
2- Setup DHCP on Server instead of router ( trust me its easier than you think)
3- put all setting to for clients in DHCP options
4- reserve IPs for servers/prineters/switches etc.
5- set all clients for DHCP
6-disable DHCP on router.
let me know if your need help setting it up.
i hope this helps
good luck
Amar Sondhi
2answers
When I tried to send email from Outlook, the Internet Service Provider replied -ERR [AUTH] invalid user/password. How can I correct this error?? My ISP is att.net. I have not found a solution on that...
This means that your user/password combination is wrong for that email server. So double check that you have the right password and user name entered for that account in Outlook. If you're 100% sure you have it right, then you might be using the wrong email/authentication server. If you continue to have problems and are located near Washington DC, feel free to contact me through my website.
Nov 03, 2009 • Yahoo Mail
Can't access log in pages for gmail and yahoo
Maybe you can work around this problem by using Windows Live Mail, it lets you access all of your email addresses on one page, Also when you set it up, you just have to enter the email address and it automatically sets up the rest, works pretty good.
Not sure about the website thing though.
1helpful
3answers
Cannot access Yahoo Mail box
just signed up for new e-mail account and can log in alright but won't load e-mails at all.
Nov 12, 2008 • Yahoo Mail
9helpful
4answers
Can't open my yahoo email address
my yahoo mail id is [email protected] is locked
how to open my mail plz reply to [email protected]
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
