HP Officejet 6500A Plus Wireless e-All-in-One Inkjet Printer, Copy/Fax/Pr Logo
A
Anonymous Posted on Mar 11, 2014
How to remove print head in a HPOffice jet6500a
Mark Dignan
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 02, 2014
Mark Dignan
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
199
Points
Turn printer on. Lift the entire top of the printer up. The ink cartridge tray will come to the center of the printer. Push the plastic tab of the cartridge you want to replace and lift it up and towards the back.Remove all wrappings on your new cartridge and reverse this procedure to re-install.
My canon pixma ip1300 is showing service error 5100, not printing and yellow light blinks five times thanks in advance..........
Solution: Install the print head and ink tanks correctly iP3000 / i560
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Power on the printer.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove the orange tape securing the print head lock lever, and raise the print head lock lever.
    Note: If the top cover is left open for more than 10 minutes, the print head holder will move to the right. If this occurs, close the top cover once and then re-open it.
  5. Remove the print head from its package and remove the orange protective cap.
    <1> Electrical Contacts and Print Head Face's Nozzle Area
    <2> Ink Supply Filters
    Note: To avoid any damage, do not touch the print head face's nozzle area, electrical contacts, and ink supply filters. After removing the protective cap, set the print head into the print head holder immediately. Do not re-attach the protective cap after it has been removed.
  6. Set the print head into the print head holder, and lower the print head lock lever until a click sound is made.
    Next, install the ink tanks.
  7. Remove the cyan ink tank (BCI-6C) from its package. Pull the orange tape in the direction of the arrow to remove the wrap film completely.
    Note: Remove the orange tape completely. If the orange tape is not completely removed, it may interfere with printing.
    <1> Removed correctly
    <2> Removed incorrectly
  8. Hold the ink tank as shown in the image below. Twist the orange protective cap in the direction of the arrow, and remove it.
    Note: Remove the protective cap while holding it, so that fingers will not be stained by the ink.
  9. Insert the ink tank into the slot at the right end, and push down on the PUSH mark on top of the ink tank until a click sound is made. Install the other ink tanks in the same manner.
  10. Close the inner cover and top cover.
    Note: Check that each ink tank is installed in the correct position:
    Properly installed:
    Improperly installed:
    <Left Image> The M ink tank is not fully seated.
    <Right Image> All ink tanks are not fully seated.
2answers
How do you remove the print head from a canon ip4600?
You will need to open the ink cartridge door and let the print carriage go to the middle. Then, remove al ink cartridges and lift the latch to remove the printhead. This video shows another Canon printer, but same concept:
How do you remove used ink cartridge?the printer is out of black ink
Removing the Print Head / Ink Tanks Instructions to properly remove the print head or ink tanks. Remove the ink tanks before proceeding to remove the print head.
Remove the Ink Tanks
  1. Confirm that the printer is powered on.
  2. Pull open the paper output tray.
  3. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Open the inner cover.
  5. Remove the ink tanks by pressing the tab of each tank.
    Caution: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. Make sure to remove the ink tanks one by one.
Click to return to the top.
  1. Raise the print head lock lever.
  2. Tilt the print head slightly towards the front of the machine and lift out gently.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>. Doing so may cause printing problems.
Canon Pixma IP4000 cyan ink will not flow even though I have repeatedly cleaned and deep cleaned and replaced ink tank.
If you have gone through the process of cleaning and deep cleaning, as described by canon, and you still get no ink flow after printing 2-3 pages, the print head needs to be replaced.
Here is WHO to contact and HOW to install the print head:
WHO: Purchasing a Print Head
You may purchase a print head* for this printer by calling 1-800-828-4040 Monday-Sunday 8:00 a.m. - 12:00 midnight. EST, excluding holidays. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance. Be sure to have your model number (iP4000R) or part number (QY6-0049-000) ready for the sales person.
HOW: Install the print head and ink tanks correctly iP4000/iP4000R/iP5000
    Properly installed:
1helpful
2answers
Five flashes pause then a further 5 flashes
This error mean "non installed or defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number is QY6-0057.
HPOffice Jet 6110 xi All-in-One printer is hooked up but will not print. Please help ...
Visit the below web link and download the print diagnostic utility.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-4&lc=en&dlc=en&cc=us&lang=en&os=228&product=79480
Installation Instructions1. Click the Download only button. 2. Click the Run button to begin the download. 3. Follow the on-screen instructions to begin the installation process. 4. Click Finish. 5. Click This program installed correctly. 6. To run the utility, click Start (or hit Ctrl+Esc or hit Windows key on your keyboard), All Programs, HP, HP Print Diagnostic Utility. 7. Follow the on-screen instructions. 8. If the issue continues, turn your printer on and off, disconnect and reconnect the printer cable from the computer and the printer, and restart the computer. 9. After the computer has restarted, please cancel any pending print jobs, if prompted.
1helpful
Canon MP830 print head
If you purchased the printer new, you would have had to install the print head before youput the cartridges in. The print head id he bit the cartridges clip into. So to remove the print head:
Open the cover, take out all five print cartridges and then lift the lever on the left of the print head and remove print head.
Hope this helps!
4helpful
2answers
Remove print head
There is no point in removeing a brother print head unless one is replacing it with new, not cleanable totally different print system to most brands. Head burns out heater elements, rather than blocks.
Yes remove every screw in top cover, all cables and post.
print head detached from rail by sliding to left end then back and up.
You are wasting your time trying to clean a brother type print head.
k24674
Grand Canyon Tech
Grand Canyon Tech
