I own a GE profile range, model # JBP70. On the smooth glass cooktop there are two burners that have a dual operating mode (either a ''large'' or ''small'' element can be used). Recently one of the ''burner'' elements has started acting up. When I select the ''small'' burner option with the control switch, a small portion of the large element glows dimly. Just the outermost ring of the element is energized. I have read conflicting reports as to the problem: some say that the element itself is bad, other claim that only the control switch is malfunctioning. My question is: what is the best way to troubleshoot this problem? My first inclination is to swap the control switch from the other small/large burner element to see if that works. I expect the two controls are identical but am not sure. Any insights would be appreciated. Thanks -Ed
If none of the burners are working but the pilot light does you are having a power problem and only getting 120 volts to it. Check the breakers to make sure they are on correctly. 240 volts is needed to operate the cooktop. Hope this helps. Rick
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
You have to access the underside of the cook top. Does the back right work correctly? If so switch the wires on the back left to match the right burner.
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
The burners are controlled by switches, that are the one you turn when you turn the knob. Iwf the burner does not switch to high mode than you need to change the switch. The switch for your appliance has part number: WB21X5243 You can by the part from manufacturer clicking here.
Here is an exploded view of your kitchen panel.
The switch is indicated with number 3 in the picture, There should be at least ttwo of them, depending on the model. That is what you need to replace. Its price is $40.50 from GE.
If our posts had been helpful do not forget to accept the solution.
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
