My 2006 infiniti m35 sport isn't playing any sound out the speakers no audio everything works screen shows radio station on can choose a station can put cd player on and play disc but no music volume goes up and down fine when I hit the voice command button I cant hear it threw speakers and if I reply with a request such as play cd it wud play cd but no sound did a speaker test in setting and all speakers went off properly can a bad amp cause all speakers not to work sometimes out of no where music might come on and play for a lil. but then cut off been like this for bout 6 months but wud like to fix it I was told that it had a bad amp and isn't getting the full 12 volt needed to power up the amp can that cause all speakers not to work? am thinking of getting a new amp but doing a lil more reseach before I do.
Yes an amp that is not working could cause this to happen. But I would check it out a little more because when you did the speaker test and all the speakers worked then that doesn't sound right. Find the amp and it could be just a loose connection that is giving you all these problems. Good Luck
Testimonial: "I checked it myself and connection were all good brought it to a audio shop that installs music ect. they did a diagnostic test for $75 and told me it was a the amp and that it wasn't putting out the 12 volts needed but like you said did a speaker test and they went off but one by one wondering if it has enough juice to do one speaker at a time but trying to power all speakers is to much and not enough voltage thanks for your reply don't kno how to contact back in fourth with a message new to this so wrote back on this if you cud get back to me wud be great."
email is [email protected]
Did anyone find the problem to this? My car is currently doing the same
