I have just purchased F20 sat nav on eBay, unfortunately there are no instructions included. I have tried to download but Adobe would only part download. Are there 'hard' manuals available?
Download.comResults 1 - 10 of 1697 - sat nav free download - TV Remote Controller (ARM/XScale), Virus ... Includes detailed instructions, with maps and street view images of.
www.pcadvisor.co.uk > ... > How to update satnav maps
Dec 17, 2013 - How to update satnav maps: TomTom, Garmin and Navman charges ... purchasing, you are entitled to download it and update your device for free. ... when i bought my Garmin, there were roads both new and old that were not ...
It sounds like you have muted your F20.
If this is the case you need to turn on the Sat Nav (outside so it picks up the Sats). Once the sats have loaded and machine is working. Press the arrow button bottom right, which takes you to map pages, press the screen on an empty area on the map page. This will bring up another on screen menu which gives you another 6 options (these include pausing routes, brightness etc..) one of the options is 'mute' (top right on screen button) press the button once and you should be un-muted.(It is one press to mute and press again to un-mute). Once un-muted, use the side + & - keys to raise and lower volume.
Hope this helps, if you are already un-muted and still have no volume, you may have a faulty unit. You could try a master reset by inserting a pin into the reset hole on the bottom of the unit.
Unfortunately, the maps for this device are not free. If he didn't send you the USA map you will probably have to buy it on SD card from their website. Sorry I couldn't be more help.
I have recently acquired a Navman F20 Satnav with a broken USB port (It was rattling around inside the unit.)
I took apart the case and re-fitted the USB port with no problems at all. Just with a steady hand and a fine tipped soldering iron. I also superglued the port in place to add extra strength.
Put it all back together, and it now charges and connects to the PC exactly as it should.
So, before you throw away a sat nav with this problem, contact me and I can fix it for you, or, alternatively I will offer to buy the broken unit from you.
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
GO TO PREFERENCES ,LOCALIZE , LANGUAGE, UK OR US ENGLISH . EXIT BACK TO LANGUAGE , TAP VOICE , MALE / FEMALE TAP TICK . ALSO INCREASE VOLUME ON SIDE OF NAVMAN + OR -
