I have a Panasonic 7000 T2 that I haven't used in a while. I have a cord that goes from the keypad to the cash drawer and a power cord. There are two other outlets market CMT and CRT. Do I need cords for these and where do they go.
SOURCE: Casio cash register te-4500f
Hi.
E10 means drawer not closed within the given time (in programming). if you have the drawer closed already, make sure all three wires are connected between the drawer and the register (one of them senses the drawer state). Apart from that, you might have a programming, or memory issue. Has anyone played with the programming?
If you are still stuck, let me know.
Mark
SOURCE: Casio CE-2300 Cash Register
Hi.
It sounds like a hardware problem, not programming. I would look at the drawer latch mechanism in the back of the drawer. Check the wiring to the solenoid (metal block in the back of the drawer). Make sure the drawer can be opened with the trigger underneath - this will tell you if the insert is jamming it, or the mechanics of the drawer are the problem. Apart from that, it is usually a drive fault in the electronics. Since this model is dying off rapidly now (the printers were a bad design by Epson), I wouldn't spend too much on it if I was you.
Mark
SOURCE: CE-7000 Program Departmental Names and program post receipt print
Hi.
Turn key to program.
3 SUBTOTAL
100000000000
RECEIPT
SUBTOTAL
That should allow you a post receipt.
To set dept names:
2 SUBTOTAL
Department number
05
SUBTOTAL
Type new name
CASH
SUBTOTAL
If it gives an error when pressing CASH, then repeat, but press 00 button before CASH (some models need this).
SOURCE: I need to find a replacement cash drawer for a
Go to acedepot. They have them for 49.95
www.acedepot.com/redrforroal6.html
SOURCE: sharp cash register (er-a470) won't turn on.
If the machine is dead, then you probably have a bad battery. It should be changed every 3 to 5 years by the dealer. If it has been left too long, then this is a common symptom and the machine loses all programming. Otherwise, you may have a faulty power supply or mode lock unit. It sounds like you need to see a dealer about it.
If anyone is looking for a Sharp ER-A470 manual, see here:
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Many more available at
