My speakers are blown how can I replace them?
Hello Courtney,
Unfortunately, Dell does not have any information available for removing/replacing the speakers in your laptop. You can click on the link below to download the online owners manual. Within the manual are step by step instructions for removing/replacing other parts in your computer;if needed.
Inspiron 6000 Owners Manual
Product Support Dell US
Thank You,
Dell-Jesse L
Dell Social Media and Communities
SOURCE: Getting a copy of the operating System cd for Dell Inspiron 6000
Dell not being provided with system operating disk aka Windows nor drivers disk needed for their systems. This always poses a problem when these people are advised to do a repair install or other system repair, only to discover that they have no disks. The normal solution recommended is to contact Dell support and ask for the disks.
Dell has a support site where you can order disks for your system as well as other important links to updated drivers. On the site Dell states:
Dell Customers can now request a set of backup discs containing the factory-installed operating system as well as the device drivers and utilities specific to your system.
Requests are limited to one (1) set of backup discs per system purchased.
The backup discs requested must match the operating system that was factory installed on the original order.
Please note that Dell will provide you the most up to date Resource disc available, containing the latest drivers and diagnostic tools currently being shipped on new systems. Due to the frequent updates, this Resource disc may not have all the drivers needed for your specific system, especially if it is over one (1) year old.
Complete details here.
Good Luck / Please dont for get to Vote.Thank you.
SOURCE: dell inspiron 6000 wireless driver
Try this one not sure what dell's problem is you'd think they could come up with drivers that work for their hardware
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R155386&SystemID=INS_PNT_6000&servicetag=&os=WW1&osl=en&deviceid=5896&devlib=0&typecnt=0&vercnt=7&catid=-1&impid=-1&formatcnt=1&libid=5&fileid=207280
SOURCE: Dell Inspiron 6000 not picking up wireless signal
There are lots of problems of using wireless LANs in metal buildings, especially if you are trying to go outside the building and into another building. What I have had to do where I work is put an external antenna on the wireless router and use that to transmit the signal beyond the metal shell of the building.
If that still does not yeild satisfactory results, you can set up another wireless router in the "home" location with an external antenna to act as a recieving point for the other router in the office ... essentially this is setting up a site to site network. With both routers working together you should resolve the wireless drop out issue.
Bestbuy also sells a Wireless Booster, this works the same way as I explained with using two routers however if you go that route be sure you have the option to either add an antenna or you can place it near a window (glass cuts down on your signal than steel).
If this fails look at replacing the wireless card; this setup will still provide benefical even if you need to replace the card as it will provide stronger signals in stormy weather as well.
SOURCE: Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
SOURCE: Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
Dell inspiron 6000 laptop battery URL(UK shop): http://laptop-battery.org.uk/laptopbattery/1001074.htm
Dell inspiron 6000 battery URL(US store): http://www.cheap-laptop-batteries.com/laptop-battery/dell-inspiron-6000.htm
Dell inspiron 6000 battery URL(AU Buy): http://laptop-batteries.com.au/computer-battery/dell-inspiron-6000.htm
