That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
try connecting it to a pc with usb cable if it charges then its the power supply if the same issue occurs then the device has a problem most likley battery is faulty
