TDK Sound Cube - Black TP6701BLK Logo
h
h mayes Posted on Mar 11, 2014
Cover Removal How do I open the box to repair loose connection inside?
Where fuse box is located, internal, on 2004 s-10 auto volvo
Hi Debra, The fuse box for the Volvo are on the passenger side end of the instrument panel behind the cover....the passenger door will have to be open to access it and it is just prised off with a small screwdriver, the fuse removal tool should be inside and the fuse list should be on the reverse of the cover but I think it is No 13 fuse you need to replace!
1helpful
My rear hatch is stuck like its locked but its not how can i get it open to work on it
You will need to pull away the top of the inside cover (area under the bottom of rear window) from inside the cargo area. Pull as many screws as you can easily, and pull out on the area of the interior cover and slide your arm inside to grab the lock rod. Once the rod is grabbed, slide it to the left and right while someone operates the outside door handle. The hatch should unlock and open to allow total removal of the interior panel and allow access for repair and inspection.
How do I change the cabin air filter in my 2009 Nissan Maxima?
If you are quite comfortable working on cars you can do this. The in cabin air filter is accessed through the glove box opening after removal of the glove box.
There is a small panel covering the right hand side of the glove box which will pop off if you pry lightly with a standard screwdriver
Then there are eight philips head screws which must be removed. Three are at the bottom of the glove box, three more are inside on the top and two are located inside at the rear top of the glove box. Once these are removed and the glove box is pulled out the filter is accessible, but not very easily seen.
It is located on the far left side and covered by a black plastic cover. You can reach in and push up lightly on the plastic cover removing it.
The opening is smaller than the filter and that makes removal and replacement difficult, but the filter is flexible and the pull tab can be used to extract the old filter. The new one can be squeezed and pushed into place with the air direction arrow towards you (the same orientation as the one removed). Replace the plastic cover and reinstall the glovebox by installing the eight screws and the side cover.Thanks for choosing Fixya,
RJ
Read more: http://wiki.answers.com/Q/How_do_you_replace_cabin_filter_for_2009_nissan_maxima#ixzz1MYGWxc6K
14helpful
The lower glove box on my 2009 Rav4 won't close. It feels like something has fallen behind it. How do I remove the glove box door?
I had the same problem with my 2009 RAV4 lower glove box. I removed the box by popping the top front right post and then the top left front post from theside housings by prying them free with my fingers. They pop out easily. I then let the box fall open and while holding it level to the floor, pulled forward, released the piston from the post on the right, and the glove compartment came out without tools. There was a plastic electrical box cover, which came loose behind the glove box, blocking it from closing. I snapped the cover plate back in place and then reversed the glove box removal process. It took a few minutes and I needed no tools.
How do I replace third brakelight in 2005 Escalade
High-Mount Brake Light Removal & Installation Except Avalanche and Cadillac To Remove:
  1. Disconnect or remove the following:
    • Negative battery cable
    • Open the hatchback door
    • Pry open the center high-mounted stop lamp (CHMSL) access cover with a trim removal tool
    • Electrical connector
    • Screws and the CHMSL
To Install:
  1. Install or connect the following:
    • CHMSL with the screws. Tighten to 17 in lbs (2 Nm)
    • The CHMSL access cover
Cadillac except Escalade EXT To Remove:
    • CHMSL retainers
    • Lower the hatchback door
    • Raise the CHMSL
    • Electrical connector and CHMSL
To Install:
    • Mounting screws into holes. Tighten to 10 in lbs (1.2 Nm)
Avalanche, Escalade EXT To Remove:
    • Rear compartment cover
    • Cargo box bridge center mounting screws
    • Panel assembly from the vehicle
    • Electrical connector.
    • CHMSL fasteners.
    • Remove the CHMSL from the cargo box bridge center bar.
To Install:
    • CHMSL to the cargo box bridge center bar with fasteners
    • Electrical connector to the CHMSL
    • Panel assembly to the vehicle. Tighten to 62 in lbs (7 Nm)
Seems to have no power but plug has power
Hello- First find power box under unit. Unplug power, open cover and inspect connections. If there is a problem- loose or bad connection-  repair and see if it will run. Let me know if this info helps- have more if needed. Thanks -Ed
3helpful
2answers
Where is the fuse box that is supposed to be under the stearing wheel
Mazda 323/MX-3/626/MX-6/Millenia/Protégé 1990-1998 Repair Guide
1994 Mazda MX-6 2.0L MFI DOHC 4cyl
Circuit Braker
A bimetal circuit breaker is located in the joint box, which is just above the interior fuse panel. This circuit breaker protects the rear window defrost circuit and is the plug-in type.
Fuses
The main fuse block is located inside the left side of the engine compartment near the battery. There is also an interior fuse panel located just above the left side kick panel.
Fuses Replacement
CAUTION Never replace a blown fuse with one of a higher rating. Severe damage to the vehicle, electrical harness and components, as well as personal injury or even death could occur.
Main Fuse Block
(see Figure 1)
  1. Disconnect the negative battery cable.
Fig. 1: Remove the fuse box cover, located in the engine compartment, to access the main fuses for the vehicle
  1. Unhook the lock tab from the main fuse block cover and open the cover.
  2. Pull the fuse from the main fuse holder.
  3. Installation is the reverse of the removal procedure.
Interior Fuse Panel
The interior fuses simply unplug from the fuse panel. Use the fuse puller tool provided with your car to remove fuses from the panel. The tool is located on the back of the interior fuse panel cover.
Relay
The main relay box is located on the upper left-hand side of the firewall (bulkhead). There is also a relay box mounted inside the vehicle under the left side of the instrument panel.
Relay Replacement
  2. If replacing a relay at the main relay box, disconnect the electrical connector and slide the relay from its mounting bracket.
  3. If replacing a relay at the interior relay box, simply unplug the relay.
  4. Installation is the reverse of the removal procedure.
Fig. 1: Typical fuse box and panel locations and configurations
I hope help you with this (remember rated this help) Good luck.
Moved washing machine and now it won't run
Sounds like a connection may have come loose in the move.
The top cover comes off fairly easily with the removal of some screws in the back. Once screws are removed, slide top cover toward back of washer and take a peek inside looking for loose/disconnected wires.
2answers
My cd/radio all the sudden stopped working maybe fuse??
There are two fuse boxes. One is located on the kick panel in front of the passenger side seat. Remove the big cover. Inside there is a second cover that ultimately gets you to the fuses. Try #20 (reference the template on the inside of the cover). There is a second fuse box (high current fuses) inside the engine compartment (on the passenger side of the compartment, big square plastic box). Fuse # 56 (reference the template inside the cover of the fuse box). Same deal.
By the way, there is a fuse removal tool inside the interior fuse box (white plastic piece on the left side of the box). You will need that removal tool to work on the ones in the engine compartment. That other box doesn't have a tool.
Hope this helps.
Top TDK Audio Players & Recorders Experts
August Brown
August Brown
Trond Baarli Olsen
Trond Baarli Olsen
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
