Heard a loud pop last night, TV suddenly turned off, no sound. Check surge protector and no issues with it since my xbox, blu-ray and Dish receiver all turned on with no issues. Unplugged the TV for 30 mins and tried to turn on the TV, it did not turn on. Waited overnight and still the TV did not turn on. Bought the TV on Black Friday in 2011, no issues with the TV since i bought it.
Probable power supply failure...
http://www.shopjimmy.com/megmeet-mlt668tl-vm-power-supply-unit.htm
Testimonial: "Thought so, Is it a easy removal and install? Thanks for the suggestion. Also, would this work as well: http://www.shopjimmy.com/aoyuan-ay280l-4hf01-power-supply-backlight-inverter-rebuild.htm"
To make sure you order the correct power supply, open the TV and look at the part numbers on yours....if in doubt, do not order....send me some Pix.
Opened it up and here are the pix. Let me know if you need clearer pix.
Power supply MLT668TL-VM confirmed ....
so your confirming i need to replace the power supply? just want to clarify. thanks
Confirmed part number of power supply.Next step is to measure the voltages the PS produces. Then decide to order it for replacement to see if it is the "fix".
OR, just change the PS and see.....
SOURCE: After a sudden power surge the screen is frozen.
unplug the set from the surge protector and leave unplugged for over an hour then it should work just fine
SOURCE: I turn my tv on the picture and sound all work and
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
SOURCE: TV red "on" light not coming on. Cannot get power to TV
SHARP LC-42D64U
The Tv will come on , however the screen is barely lit. Meaning its like watching an xray ( black and white ) images. There are no warning indicators of any problems. Also sound quality is good but shadows of what is on tv. Any solutions on what needs to be replaced?
Thought so, Is it ae asy removal and install? Thanks for the suggestion. Also, would this work as wellhttp://www.shopjimmy.com/aoyuan-ay280l-4...
