My konica minolta bizhub c35 is recognizing a new black toner cartridge as empty. how do I fix this?
Gee many fixes. look for clear optical port and place a small piece of masking tape over it. tilt left and right to horizon slowly and install
Sir/mam replace the cart then might have gotten a bad one from the store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
SOURCE: Konica minolta 2500w doesn't recognize that toner cartridge is installed
Sounds liKe the toner dust is bvlocking the sensors. see the following
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
