My bizhub is recognizing a new toner cartridge
Replace the cart then might have gotten a bad one from the store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Toner cartridge end of life message
Just unscrew the side of the toner and reste the metalic plastic tab (silver ..) and that's it
SOURCE: Toner Cartridge reads empty
did you change the microchip with the cartridge. also i believe that you can reset the levels in the menu
SOURCE: new toner cartridges were inserted and they are
You need to make sure that all sticker removed from the ink and that the vent are clear…some of the issue may cause the printer to give wrong reading especially if you touched the ink sensors or got ink around the housing from outside, as far as the level if you ran the alignment or self-cleaning that use lots of ink too
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
SOURCE: Konica minolta 2500w doesn't recognize that toner cartridge is installed
Sounds liKe the toner dust is bvlocking the sensors. see the following
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
SOURCE: SCAN TX FAILED mesasage on bizhub C35
Settings not set up properly, drop me a line i may be able to help
as empty. How do I fix this? Please advice
