Homelite that won't start new plug fresh fuel no spark
Most of the time on older engines, the carb needs to be rebuilt or replaced. Dont panic rebuilding is cheap an easy. The ports get clogged up sitting an varnish up. Try to clean out all orifices with small pieces of wire from steel or brass brush. Use carb cleaner to clean replace all gaskets an parts with kit. Dont forget to check fuel hose in tank they go bad often an should be replaced when carb work is done. Fresh gas an it should work
SOURCE: chain saw no start
It needs spark, fuel and compression to run, which is missing?
Lets start with spark. Replace the plug (very inexpensive and great insurance), then do this:
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Before we get to fuel please download and follow the start procedure in your Operator's Manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I own a Husky 359 that 1 time I forgot to set the fast idle (close then open choke). It was near impossible to start. I have missed the initial attempt to fire and flooded it too, again almost impossible to start.
If it has spark and the start procedure fails, put a teaspoon of fuel mix in the carburetor throat, open the choke, and pull. Does it fire and attempt to start? Yes it probably has a fuel delivery problem. Please repost with what you did and we will continue. HTH
Lou
IMO regardless of what your manual says ( yours probably 50:1) all 2-cycle engines should be operated on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle engine oil). Once adjusted for this mix they start easier, pollute a bunch less, and do not foul out plugs, cylinders, or mufflers. Run lean conditions are most often caused by dirty air filters, air leaks not detected by the operator, or failing to add any oil to the fuel in the tank. Using a 32:1 mix prevents none of these occurring! I use a Pioneer chainsaw I purchased new early 1980 with a 50:1 mix.
