Machine starts and runs normally for about 5 mins, then makes a noise like it's trying and failing to do something; clicks after each attempt, then stops altogether and the start light flashes twice.
That sounds like an overheating problem. When the machine pauses, the blower fan stops running and that allows the heat to build up enough to trip the high level thermostat. You can test this by running a cool cycle.
Drive belts don't squeak because they are made of rubber. Things that do squeak are rear drum bearing, front bearings or drum slides, idler pulley wheels or the tension springs.
The machine needs a full strip down, cleaning, de-fluffing and lubrication. Also check the exhaust hose and the grill outside except it appears you have a condensing dryer. Make sure that unit is clean..
check and see if compressor is running it is in the rear behind the cardboard cover if it is super hot then you need to get a tech out to look at it and it may still be under warranty
My dishwasher isnt working anymore after i cleaned the filters?
i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere? It is a Whirlpool ADP 5540 thanks for your help ****
the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
