My casio edifice EF527D-1AV, the crown keeps poping out and the watch stops. The seconds hand moves but the minutes and hour time will not. Does not tell time. Help needed
SOURCE: Casio Edifice Watch
Here is a link to the manual: http://ftp.casio.co.jp/pub/world_manual/wat/en/qw1310.pdf It says: Hold do the (A) button [the upper-right button] to advance the analog time setting. The analog time will adjust forward at high speed. It only goes forward, so if you miss the proper time, you have to go all the way around again.
SOURCE: setting the analog dials on the casio edifice EFA 120
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Go here to get the instruction manual
SOURCE: Casio Triple Sensor Pathfinder PRG60-1AV
Like anon129 I had the same problem. Those "outdoor" functions need more battery power than just telling the time and the stopwatch do. When the rechargeable lithium battery gets old and tired - which they apparently sometimes do for no very good reason - it can't provide enough power when required to, so it goes into recovery mode. It's very annoying but if your battery level indicator is already showing H the only solution is to replace the battery.
My second battery seems to be lasting better, but I'm not leaving it charging in the sun for ages this time, as I think it overheats it when the battery is full. I'm also not using the outdoor features as much, and the light hardly at all.
SOURCE: CASIO EDIFICE Watch Model #:EF-527D-1AV
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
SOURCE: How can i set date and time in my CASIO EDIFICE
Check out my tips and tricks. There you will be able to download manual for your Casio watch.
