2007 Honda Accord Sedan Logo
Posted on Jun 13, 2009
Reset radio but can't reset clock
I recently replaced the battery in my 01 civic and I had the radio code handy and got that working no problem. But I can't reset the clock. It just flashes the wrong time like your digital clock at home after a power outage. I've tried the usual way of reseting the clock (put ignition in Accessory II, hold down clock button, press preset 4 for hour, 5 for minute) but to no avail. What can I do??
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Oct 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
7360
Points
42
Just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
07 cx7, changed battery, now now radio controls to set clock won't work.
have to check manual for reset codes for radio should fix
1helpful
3answers
Reset clock/radio 2011 honda civic after battery cha
go to myhonda.com and register with your VIN number. Then you can get the unlock code
2answers
If I don't have a scanner how do I clear codes on 2005 e 350?just replaced tft sensor.
You can purchase a code reader that has the ability to remove the code after repair. It might not read all codes but can be handy in today's electronic world
2helpful
Radio dose not work
It can be issue with radio fuse or wiring issue of radio.
First test the radio fuse.If its blown out,then replace it.If the fuse i checked ok,then its radio wiring issue.Test the voltage.
Check out few help links provided below,related to car radio problems:---Click the link below:---
Radio Controlling Fuse Location? http://howtobyme.blogspot.in/2012/05/2003-lincoln-aviator-radio-controlling.html
No clock, radio, gps, climate control After Battery Cross Jumped? http://whatisbyme.blogspot.in/2012/05/2006-lexus-ls430-no-clock-radio-gps.html----------
XM satellite radio interface kit Connection? http://technoanswers.blogspot.in/2012/04/toyota-avalon-toyota-xm-satelite-radio.html
Radio Power Antenna wiring diagram? http://technoanswers.blogspot.in/2012/02/radio-power-antenna-wiring-diagram-for.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
2006 Ford Expedition radio not powering ON? http://technoanswers.blogspot.com/2012/01/2006-ford-expedition-radio-not-powering.html
How to reset Radio code after car battery is died? http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
These details will help.
Thanks.
I have a 95 Honda civic. My cig. Liter works but my radio won't turn on no matter what I do. My clock resets every time I get in the car. I've replaced my wiring harness the fuse in my radio is...
Don't know if yours is one but some 95 Honda civic have a antitheft program. If the battery ever goes dead or voltage is removed from it, it will not work until a program code is given to bring the radio back to life. you might want to try searching 95 Honda civic radio code.
I replaced the battery on my 2008 Honda Civic & now I have an error code 9 on the radio which does not work. How do I reset the clock & radio?
you will have to check your glovebox for manualy, there is also a card with the radio code, if you cant find it then the radio has to be removed to get serail # and then call the dealer; they will give you the code.
Got 1998 Honda Civic - both clock and radio lose memory when ignition is turned off any ideas why this is? Power to getting to both radio and clock but memory goes.
There should be a backup radio (clock) fuse (probably in your inside-the-car fuse box). Sounds like it might not be there, or it is blown. It is normally removed in order to clear trouble codes from the computer.
When you do that (remove it to clear trouble codes), the clock and the radio have to be reset, so it sounds like that fuse may be missing (the car will run without it).
Hope this helps you.
3helpful
2answers
Battery ran down.now radio/clock don't work. flashes Error.can this be reset?
try taking the radio out and looking on the top for the parts number. call Honda and tell them what is going on and they will give you a 4 digit code that will reset the radio. i had the same problem with my 05 civic, did that and it worked for me.
good luck
1helpful
TSX reset radio code didn't work
Same problem with a 2002 3.2 TL; was jus advised that when OnStar switched from analog to digital it causes memory dump; dealer says it requires "hard reset" which costs ?$?; Acura 800 number says disconnecting antenna may/may remedy.
BATTERY REPLACED NEED CODE FOR RADIO
You will need to take it to a dealer, They will have all codes on file under your plates.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
