Linksys Wireless-N WRT150N Router Logo
A
Anonymous Posted on Mar 10, 2014
Trying to connect hp printer to wrt150n - Linksys Wireless-N WRT150N Router
nick campbell
Level 1:
Habit-Forming:
New Friend:
  • Contributor 21 Answers
  • Posted on Jun 22, 2014
nick campbell
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
21
Questions
0
Helped
6918
Points
34
There are many ways to connect your printer with your linksys router:
connect your printer via ethernet cable.
connect your printer to the router via usb cable.
connect your cable to the router via wireless network
so if you are trying to connect your printer router via wifi method. then you need to go to setup on your printer and then go to wireless network option, once you will reach there then you will see there your network name and password you need to fill that network name and password on your router and then hit connect your printer will connected to the wifi.
if you have any kind of problem with any steps or you dont know your wifi password then you can contact to our helpline number :
  • nick campbell
    nick campbell Jun 22, 2014
    toll free: 1-866-283-6613
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
CONFIGURATION PROBLEM ON MY LINKSYS WRT150N ROUTER
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Re-installling wrt150n router to new computer.
ask you ISP what are the IP address and DNS server address that you need to feed in the properties setting of the TCP/IP setting in the Network Connection wizard in Control Panel
without these the connection will not work
No wireless connections between WRT150N and Vista Laptop
On the vista laptop, make certain that the firewall is not blocking the wireless connection. Try to turn off the firewall and see if that helps.
HP Imaging software hangs up intenet connection
Put the printer back in the box it came in.....
Wrt150N loosing connection
It does sound like you need to upgrade firmware. Not sure what OS you are running as Linksys are still in the process of updating Vista firmware. Anyway here is the URL you need:
http://www.linksysbycisco.com/UK/en/support/WRT150N
Sounds like you need a firmware upgrade. Here is the URL
Port lights not on
Since you already tried a different ethernet cable and still the same, you can try this just to make sure if the lan port of the router is bad or not, connect one of your pc or your laptop to the router and check if the lan port of the router will light up. If the port light of the router is on when the pc is connected to the router better check the lan connection of your printer.
2answers
Can't connect wireless to WRT150N.
Your hardware might not be compatible with eachother.
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
