My problem started with the machine continue to flow with water and does not stop even when overflowing and washing does not take place. the next day the machine won't start and it loses the beep when button is pressed. when at time i heard the bip when a button is pressed, the machine worked perfectly but only for a complete washing circle. please help.
SOURCE: today is the day my microwave stopped working
Magnatron is suspect.
Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there)
Should be getting 120Vac when it goes to cook cycle.
Don't touch the other (high voltage) side of this transformer.
If the power is there, you are looking at replacing the magnatron.
Could also be the high voltage capacitor or diode.
Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
SOURCE: Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
SOURCE: i cannot press start and stop button i think
Normally, it suggests the keypad is faulty. The fact that you have part function indicates the board is functioning. Replace keypad.
