Question about Jet Tech Systems 28 in. 747 Free-standing Dishwasher
Wash arm hub broken - Jet Tech Systems 28 in. 747 Free-standing Dishwasher
    Problem Solver:
  • 25 Answers
SOURCE:
Upper arm of HJA 8362 keeps falling off. Could there be a part missing/broken?
yes - the clip that holds the arm on is probably broken off or weak. Order a new spray arm and spray arm support tube - a new wash basket will probably come with these parts on - but check first as some don't.
Jan 31, 2018 | Dishwashers
GLDT690TBB
In order to have a spinning wash '''blades''(arms)...the machine must take water from the tank ...through one pump...manifold...wash arms...dishes..
Can be..impeller of the pump is broken..especially if is plastic one
the wash motor is not running
Good luck
Jun 29, 2013 | GE Dishwashers
Middle wash arm and top wash arm not turning. Water comes out of two outside holes on middle wash arm....
Is it filling with enough water? If not sure dump another gallon of water in there once it stopped filling. If still not working I would take the pump apart and check for excessive blockage anywhere or broken chopper. If everything looks good then you probably need a new motor with impeller.
Sep 24, 2011 | Kenmore 24 in. 16019 Built-in Dishwasher
My plastic drum seal on my Whirlpool duet front-loading washer is chipping apart. The drum doesn't run true, is wobbly and has a rhythmic rub when turning. How do I replace the drum seal? Model GHW9100LW.
You have more serious problem than just your drum seal. The support arms in the wash tub are broken. The wash tub should always spin true. When it wobbles it is a sure sign that the suport arms or spider arms are broken. It is an expensive repair since the wash drum, the outer plastic tub and the door seal need to be replaced. Check your warranty, to see if some of these repairs can be covered. Get a few estimates before deciding whether to repair or replace it. Sorry.
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Bosch SHU 8805 upper arm is getting no water.
replace the upper water arm conduit and wash arm hub as they leak under years of pressure and the o-rings leak water and then it can't hold pressure and supply the upper arm with full pressure water,also replace the center arm conduit if it has one as this will wear out too
Mar 23, 2010 | Bosch 23 in. SHU 8805 Built-in Dishwasher
High pitch electrical sound and silver spray bar under bottom dish rack doesn't appear to be rotating on wash cycle; also 2 inch round washer under where arm screws in disk has broken, could this be it?
i would replace the lower wash arm hub and mounting components and check the silver arm for debris plugging the wash water spray holes while its off to replace the hub
Mar 13, 2010 | Dishwashers
Upper basket spray does not rotate
check the wash water conduit located on the back wall of the wash cavity from the base up to the center arm if so equipped,then up to the top arm, otherwise the arm itself could be plugged or the spray arm hub could be bad check and make sure arm rotates easily,then remove and make sure there isnt food matter plugging the spray arm holes
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
2008 Mazda Tribute - Rear wiper arm
I have used a small puller to get these off so i didnt damage the lift gate
Aug 11, 2009 | 2005 Ford Escape
Jet Tech Systems 28 in. 747 Free-standing Dishwasher Logo
29 people viewed this question
Top Jet Tech Systems Dishwashers Experts
Robert Marsolais
Robert Marsolais
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jet Tech Systems Dishwasher Expert? Answer questions, earn points and help others
