SOURCE: AC adapter not recognized
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
Check the inside of the connector, since it is new, you can call Dell 800-624-9896 for a replacement adapter.
SOURCE: dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
SOURCE: Trouble downloading skype
Can't DOWNLOAD it or can't INSTALL it? Are you saving it to your computer first to install it later, or are you trying to install it while downloading? Save the files to your computer first, then run the install when the download is complete. What method of internet are you using (cable modem, DSL, dial up)?
SOURCE: Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
SOURCE: Dell inspiron 1721 hard drive not recognized for Vista reinstall
ok, theres a small issue with the raid controller. You have to install a 3rd party raid driver (its on the dell cd) to continue, OR, you can set that BIOS's hard drive controls to ATA or LEGACY (legacy would likely work best, but youd have no 'raid' functions, but who sets up raid drives on a notebook?). Your last option is use the dell discs to restore, and inssert the windws disc when prompted
Testimonial: "Thank you so much! It didn't have a option for Legacy, but only RAID and ATA. But it's working!! You are super awesome!! Thank you!!!"
