CANT FIND A FILTER
SOURCE: whirlpool air conditioner simply does not turn on
Check out this article. You may find the solution. Good luck!
http://h-mac.com/blog/2008/06/05/how-to-maintain-a-window-air-conditioner/
SOURCE: whirlpool ACE244XS air conditioner blows out cool air when on hea
Due to Defective Thermostate Switch Try to Replace, will be ok
SOURCE: Replacement remote for window unit air conditioner
I have that model Air conditioner with remote. Although the remote is marked Admiral thats the only identifying marks on the outside. Here are pictures of the remote.
Top View
Side View
Battery Compartment Cover
Here is what is printed on the battery compartment cover label.
SHUNDE HUA AO
ELECTRONICS CO., LTD
Drawing No: DF11F1-01 (AL) KYK-1801
Part No: 814011422
QA: 01
Date: 2005.01.11
Hope this helps. You might try a company called Vance Baldwin they usually carry a large inventory of remote replacements for all kinds of applicances. Had to get a remote for my Panasonic DVD player and it was only $12.00 (brand new)
SOURCE: whirlpool window air conditioner 20000 btu's not cooling properly
It is possible the cover needs removed and the condenser coils are in need of a good cleaning. (the one in the back that is outside).This assuming the compressor is running and it has not developed a leak and lost the coolant charge. Eric
SOURCE: Coils freeze up
Make sure blower is running at the proper speed, if it's running to slow do to bad bearing or capacitor, the coil will freeze up.
Check evaporator coil and filter to see if they are dirty if they are then the coil will freeze up
Check the charge if it's low on refrigerant the coil will freeze up.
If your not sure how to check these things, then you should have a HVAC company, check it out for you.
Testimonial: "The comments were excellent, however, since I do not know how to checkout the suggestions, I need to have it serviced by a repair person, or I might just be forced to go buy a new one. Thanks."
