Home Logo
T
Thomas Yohe Posted on Mar 10, 2014
Aerofeel on Maax tub not working
Not quite two years ago I bought a new Maax "Jazz" (model#105359-055-001) free standing tub with the AEROFEEL air system (no pump, just air), and am just now installing it (health reasons). The air system doesn't work. The electronic components are: control panel/display; water detector switch; electronic box; cables/connectors; and the blower. The power supply is good but the display is blank. I talked to a tech at customer service and he thought the likely problem was a faulty detector switch ( the blue one). I guess they upgraded since then. Maax sent me a new one (the blue one) and I installed it. Used silicone caulk and got it set at the right height. The red indicator light was on so I presume it's functioning. I filled the tub up with hot water but the display is still blank. I even turned the tiny sensitivity adjustment screw back and forth but to no avail. How can I get this to work? Please Help!!! Tom 724-350-4296
  • US Parts Center
    US Parts Center Jun 19, 2014
    Hi Thomas Yohe, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    I need to know who made the controls on your tub. What is the brand name and is there a model number on it?
1 Related Answer
Donni Steen
  • 687 Answers
  • Posted on Mar 22, 2009
SOURCE: maax velvet bubble-tub does not work
This will tell you that the control board is bad. You will need to replace it. But before you do, make sure that the switch is telling the board to send the signal. Check to see if the board is getting the power required and that the poser is leaving the board.
Aerofeel does not work on maax tub model 105359-055
I asked the same question to the tech guy at customer service and he said no, because the water detector switch is actually a density switch, so the temperature really doesn't matter. The tub just has to be filed with water.
Feb 16, 2014 • Maax Home
My JBL Marine Hot tub Sterio quit working suddenly?
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
The sensor won't detect water in the tub. When the display does come on, and we choose a run time, it runs for 15 seconds or so and then turns off and the lights say "no h20". What can we do to get this...
I would first check that the suction intake has no obstructions. The next thing is to make sure that the jets are not pointed at the suction intake, there could be air getting into the system. You also need to make sure you have adequate water level.
1helpful
I don't know how to work my Maax hydromax double tub. We just moved into our new house and the owner did not leave instructions. Please help
Try to downlaod the manual from the maax website. Hopefully you can find the model #. Look around in the pump acess area for it. If you cant find it try to match it up with a current model image from the website or do an online image search. All major companies offer there liteture available online somewhere, maybe under a seperate tab, on the product page.
If this does't help you should post again and be more specific i.e. what can't you get to work? Tubs these days have many different feaatures. Also model # and estimate what year it may be.
Wish I could have been of more help.
Sincerely, T. Wood C&F Enterprises a plumbing contractor.
Oct 07, 2009 • Home
1helpful
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Top Maax Home Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Maax Home Expert? Answer questions, earn points and help others
