Hello, guys. I have a Dirt Devil Bagless Upright and when I bought it, it worked like a charm. Nowadays, when I try to use the hose attachment, it has NO suction, and sometimes the **** thing won't even pick up dirt. I opened every area I was able to open, and cleaned out and wiped down, but if the hose is not picking up, then what else should I do?
SOURCE: No suction on kirby g4 upright vacuum. Can't use attchments.
First remove the mini-emptor and check for a clog also check the fan for anything cloging that or the hose may be clogged
SOURCE: Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
SOURCE: my dirt devil upright dynamite vacuum does not
That means that your belt is worn, stretched or broken. You need to replace the belt. You can get replacement belts and view the manual:
Dirt Devil Dynamite M084600 Belts
Download the Manual (PDF)
