What should I do if once I turn on my Ac my idle drops as if it's gonna die, and .... to a complete stop the rpms start going up and the car accelerates on its own. ... Honda Accord LX, and my Honda just started sputtering in idle. check engine .... My cousin replaced my radiator on my 90 civic and since then my temp gauge is ...
Jun 11, 2010 - 1990 Honda Accord Ex F22 209000 miles, recent alternator change When I ... When I take off from a stoplight I get a little hesitation/bogging/sputteringfeeling until about 2,000 RPM then ... My 1999 Accord had a similar problem (F18B2engine). ... It only lasted a second or so before it would actually rev up.
lost 12vdc power, you did,
or engine only makes 1 horse power.... not likely
clean the battery , lugs. ends.
you never said you cant drive car??
i start engine and drive , can i drive.? ok>? HL off.???????????
? Y/n
if yes,the lugs are bad or corrosion from battery to main fuse boxes
could be both at about 20 bucks apiece i would do both. would start with the thermostat you cause you can check it in a pan of water. but it prob stuck open from the sounds of it. protect your environment collect antifreeze in clean container re use
On the throttle body, that's the part where the throttle cable goes on, will be a screw. might have a plastic cap covering it, remove cap, and with screw driver turn screw in there to where it will idle where you want it, that the idle mixture screw.
First thing you have to do is check the coolant level. It is possibly very low on anti- freeze, or frozen up from the anti freeze not being strong enough.
I had the same problem with my honda. On the throttle body there is a screw that controls idle speed. If your idle speed is around 800-1000 rpm in neutral, tighten the screw a quarter turn each try until the idle speed is around 1500 RPM. Did this stop the idle?
