There is a big black circle spot appears on the upper left side of the screen.
You should be able to apply pressure on the bottom edge of the frame vertically below it to make it disappear. If that works get a binder clip, like they use in the office and clamp it on and the remove the silver wires from the clamp and your good until you replace the screen or upgrade your unit.
It seems your screen is bleeding. If it is not acceptable, then you can replace this screen.
