Question about Archos 504 500870 Digital Media Player
Hi I use a 504 as a monitor for a digital camera connected to an aerial system. The wire from the camera is connected through the travel connection add on. When wired up the battery always reads empty. When I disconnect the wires it reads full. Then when I connect the Travel connection it is O.K... but when I go through the menu to rec and see the picture nothing works... Can you help ? Thanks
SOURCE:
SOURCE: how do i put music to my archos?
try going in to whatever music player program your computer offers and to to file.... browse...... my computer..... and there should be a usb drive if its pluged in it will say archos.... click on it...... and select open.... then it will come up you can then transfer music to it just like any other drive or folder on your computer try windows media player go under the sync option then just drag and drop
Posted on Jan 02, 2008
SOURCE: Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
Posted on Jan 28, 2008
SOURCE: Archos 504
does the archos come from europe and you are in the US, my point is if it is off say ebay theit will be set up for 240v and therefore is shall we say starved of power.
Posted on Mar 18, 2008
  • 6 Answers
SOURCE: how do connect dvr station gen 5 to record off my tv ,
There are a lot of ways that the 605 DVR can be connect to the TV, If you let me know what TV you have I could make a reconditions - However the easiest method is to use a yellow/white,red phono cable
Posted on Jan 20, 2009
kerguney
  • 577 Answers
SOURCE: my archos 604 won't play on my television.
Hi,when you connect it to TV,I believe you switch to AV mode on TV to allow signal to be shown on TV,do you ??.
If you did it but no video ,than make sure your AV cable should go all the way down on the plug on Archos.it is a fancy plug sometimes stays out half way
kazim
Posted on Sep 26, 2009
How do I connect a field monitor?
Hi David,
I found a manual but not for your exact model....The link should show you possible ways to connect your cam to the monitor
Sony HVR S270U Operating Manual Connecting Monitor Or Tv
Hope this gives you some direction.
Thanks, and please rate if helpful!
Gary
Apr 07, 2016 | Sony Hvr-a1u 1/3" Professional Hdv...
ARCHOS 504
Did you try flashing the firmware on the unit?
Mar 27, 2008 | Archos 504 500870 Digital Media Player
I have an Alba 16 inch flatscreen tv with built in digital tv. When i try to do initial setup or auto install it says check antenna connection even although ariel is in. Can you help
Do you have an indoor or outdoor aerial?
Indoor aerials will not have the strength to pick up television broadcast signal.
Double check your connections, as you could have a loose wire or connection somewhere.
You might need to speak to someone who, can take a look at your aerial to see if it is configured correctly.
Also to make sure it isn't a problem with the aerial, do you have another TV that you can try using on the aerial. to see if you can get signal?
Jul 19, 2011 | Televison & Video
WE DISCONNECT OUR SATELITE hOW DO WE GET REGULAR TV
You must have these first.
1. Aerial antenna - buy this at your local home depot. Any aerial antenna available will be fine. Please see the sample picture.
2. Antenna wire (RG-6 cable wire) - connect one end of this wire to your aerial antenna and then the other end to your tv.
3. RG-6 connector - other end of the cable wire must have a this connector to attached it securely to your TV.
Some Aerial antenna has a cable wire packaged, this is much better than to assemble #2 and #3.
After the connection had been done, go to the menu on the tv, scroll down to antenna connection and then press auto tunning to saved all the viewable channel in your area.
Let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Jun 21, 2011 | Hisense LHD3204US 32 in. LCD HDTV
Where is the camera button. and i cant record or take pictures
The Archos 504 doesnt fit a camera. You must purchase it as an addon at Archos store or at newmp3technology.com and connect it to the device.
Jul 05, 2010 | Archos 504 500870 Digital Media Player
Arch 504 i change hard drive
You canĀ“t swap the internal hard drive if your current firmware is superior to v1.4.0, because system locks it during bootloading (system reads hard drive ID).
May 11, 2010 | Archos 504 500870 Digital Media Player
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Can't heat radio
Hi There Laura,
For you to get radio reception then you will need an aerial...
The FM stations are very weak and thus need a good long aerial to collect these weak signals.
Some receivers need the aerial to be a "loop" so and on the rear of the receiver there will be a special two port aerial connector for the FM..
You dont say where you are but if you are in the "outback' then a good long aerial will be needed...
The same can be said for the AM radio signals these are much lower in frequency but still need an aerial.
There is a difference with the AM signals as they also need a good earth as follows.
On the back of the receiver there will be an aerial connector marked AM and it will show an earth connector and and aerial connector.
There needs to be a good earth connected to the earth connection and another long wire connected to the aerial connector.
The earth should be a metal spike about 500mm long driven into the soil outside in the garden
and connected to a wire which comes inside thru the window to the earth connector on the rear of the receiver.
The aerial wire must not be connected to earth at all, but insulated.....
this wire connects to the AM connector out thru the window and up to the nearest high point. Like a tree or a pole...NOT A POWER POLE as that dangerous.
When you connect to the tree use a piece of plastic rope or something to insulate the wire from what ever it touches, as the radio signals are not allowed to come in contact withthe earth until they get inside the receiver...
You can use a wire with a plastic cover on it if you like..
You may wish to ask your neighbour if you can look at his aerial connections and learn how its done...
He wont mind.... unless you are "outback" and the nearest neighbour is 100miles away..
That makes it more difficult.
If you get stuck ask here again and I'll pass on more detail for you..
Cheers for now
From YUBEUT..
Apr 29, 2008 | Durabrand W600 Shelf System
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Dec 13, 2007 | Archos 504 500870 Digital Media Player
Archos 504
Simply said you require a DVR station or Audio/Video travel cable. On the DVR just simply plug in your composite cable from OUT the satellite/cable box or whichever source your recording from to IN on the DVR station. The a/v travel cable is a little easier to hook up. Then just select the VideoCorder icon.
Aug 12, 2007 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
51 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
