My Maytag side-by-side refrigerator MSB2154ARW is over 10 years old. It has been working flawlessly, but then lately there was water leaking on the floor. Freezer and fresh food section are cooling fine. Repairman checked it and added refrigerant, cleaning it at the back (where compressor and fan are). The temperature controls do not make any change in the operation times of the refrigerator Now, the compressor keeps working most of the time, seven and a half hours straight and then only stopping for the defrost cycle for about 25 minutes and then again runs for another seven hours. There is ice building up on the coils close to the fan and the one close to the compressor. The second repairman first adjusted the pressure of the refrigerant (not change at all on the cycle described) and then on his second visit said the problem was the temperature control assembly that we have now already replaced with an original part without change on the compressor cycle described. No matter what position you use for the temperature settings (1, 5 or 9) the compressor will only stop on the defrost cycle after seven and a half hours running.
Thermostat
Testimonial: "Thank you for the suggestion, but the control temperatura assembly that has already been replaced is called by some repairmen the thermostat". Is there another one? Where it is located. (On the freezer there is a defrost-thermostat assembly, but I do not find it associated with the kind of problema we have and the defrost cycles are working)"
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
