We are trying to figure out if it is better to repair the bottom oven heat element, or buy a new oven/stove. The bottom heat element sparked a fire, then after the fire went out, it no longer heats. The oven is about 13 years old. Plus, we are moving within the next year, so I prefer to find the most cost effective solution, repairing, or buying new. Thanks!
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
SOURCE: Baking Element Caught fire
this a common complaint when the element burns out it is scary to see but all you need to do is replace element
SOURCE: Lower ignitor bad?
As long as you replace the existing igniter with one of compatible specifications, you should be okay. The type of igniter you have is called a Carborundum and produces 2.5 to 3.0 amps. I found a replacement at searspartsdirect.com for about $68. Just type in your model number and look under the "Gas Burner Parts" heading for item number 28 (part #WB2X9154). The part number used by Sears is the SAME number used by GE and sells for about $30 less! I also found the part listed at repairclinic.com for about $64 (item 1990). Click on the following link for a complete explanation of the igniter types and how to replace:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you can find the part for less, that's great. Make sure you use the GE part number as a cross-reference to ensure you are getting the correct igniter. I hope this helps you.
you need a new clock it operates seperately from the eyes. if you have 110 volts to it and it is not illuminated .it is out
SOURCE: We have a GE gas
If you just purchase it or it is still under warranty take it back it going to cost the same to repair. You also run the danger of creating an electrical fire.
